iCloud calendar problems, Outlook shuts down immediately
Vincenzo
After installing iCloud from the Microsoft Store in Office 365 on Windows 10, the calendar sync runs ok for about a week or two. Then it fails - Outlook will open briefly, for about 1 second, then shut itself down. The only way to get it working is to start Outlook in safe mode, uncheck the iCloud plugin. Then Outlook will work.
Then I uninstall/reinstall iCloud, and it works for a while.
I have checked the pst, and created a new profile. None of these help for more than a week or two.
Any ideas?
Vincenzo
OK thanks.
I will check that if/when it fails again.
KeithJB iCloud calendar sync only works one way! Using Outlook 3
W Looks like the folder below has been deleted: "iCloud\Calendar" Using Outlook 1
V iCloud Calendar invitations not sending Using Outlook 3
M Can't Delete iCloud Calendar Notifications From Outlook 2016 Using Outlook 0
J Auto Accept Notifications from a shared icloud calendar? Using Outlook 4
V iCloud not syncing categorized calendar events Using Outlook 7
V Any alternative to iCloud for calendar sync to iPhone? Using Outlook 8
I iCloud Calendar and Contacts in Outlook 365 Using Outlook.com accounts in Outlook 2
I Icloud has hijacked my calendar Using Outlook 2
R Disappearing data from outlook calendar after using icloud-ical Using Outlook 2
R Cannot select iCloud calendar Using Outlook 5
V Sync Outlook contacts/calendar on two computers using iCloud Using Outlook 2
B icloud calendar stopped syncing, won't restart Using Outlook 1
F iCloud calendar invisible only in Calendar View Using Outlook 2
V Get Calendar back from iCloud Using Outlook 3
E Outlook 2013 , iCloud linked calendar, events one hour ahead for about a month Using Outlook 5
C Outlook local calendar & iCloud calendar syncing query Using Outlook 3
R Slow Calendar Synch Between Outlook 2013 and iCloud Using Outlook 5
C Lost calendar and contacts to icloud: Help! Using Outlook 1
S Calendar deletes appointment after entry from both Outlook and Icloud calander Using Outlook 1
G iCloud task folder not showing in outlook calendar page Using Outlook 3
S Using both My Calendar and iCloud Calendar in Outlook 2010 Using Outlook 4
M sync Outlook 2007 calendar with icloud Using Outlook 1
C Remove iCloud so I can have original outlook calendar and contacts Using Outlook 43
C Outlook Calendar Ribbon with iCloud Using Outlook 2
T Calendar sync off by 1 hour - outlook 2010 / icloud 2.1 / ipad Using Outlook 2
S iCloud Outlook Calendar is read only Using Outlook 1
N Restoring Outlook Calendar after iCloud copy Using Outlook 1
J iCloud Calendar/Contacts Syncing Hangs At End - aplzod Data Store Not Created Using Outlook 8
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
B iCloud for Windows 11.2 disconnects by itself after 30-45 minutes Using Outlook 9
