reminders not synced by CodeTwo Sync for iCloud
CheckMate
Outlook 2021 64 bit
Hi there,
I cannot get the plugin to sync the reminders/alarms of my calendar entries. All other info is synced just fine, just not this data in any direction:
a) Entry created in Outlook with alarm ends up in the iCloud sync folder (inside Outlook) WITHOUT the reminder/alarm setting.
b) Entry created in the iCalendar (either in browser or on iPhone) ends up in the iCloud sync folder (inside Outlook) WITH the reminder/alarm setting, but then LOSES this info when synced into the standard calendar folder.
Any suggestions how to get this to work? Or is this feature not supported by CodeTwo?
I'm not sure if it is supported by CodeTwo's sync, but reminders in the iCloud add-in from apple are set by iCloud, not outlook. Your issue could be related to that - especially for events created in Outlook and synced to icloud.
Do you have Outlook setting a default reminder?
@DigitalDawn had posted this on Aug. 6th 2023: "I've been using Code Two and it works pretty well. Reminders are a bit screwy but they do work for the most part."
I concluded from this remark that the reminder info from an Outlook entry/appointment is synced by the CodeTwo plugin (maybe that conclusion is wrong).
I don't have reminders turned on by default in Outlook. I did some testing and the breaking point of the sync is the connection between the "standard calendar" and the "iCloud calendar" (both inside Outlook). At the sync between these two calenders any reminder info (no matter where they were added/edited) doesn't get carried over to the other calendar (both directions).
When I set the reminder inside the "iCloud calendar" in Outlook it gets carried over "outwards" into the iCloud and onto my iPhone and vice versa (changes on my iPhone end up in the "iCloud calendar" in Outlook).
Y Q's on Appointment Reminders Using Outlook 2
T Never-ending Reminders in Shared Calendars Using Outlook 3
A Outlook Reminders not populating for certain events Using Outlook 2
J Are the underlined letters in Outlook Reminders window supposed to work? Using Outlook 4
P Reminders Window stops being displayed, even with /resetfolders or /cleanreminders Using Outlook 8
M Quicken One Step Update Bill Reminders Not Syncing to Outlook Using Outlook 1
J Reminders Display then Disappear Using Outlook 13
G Unable to dismiss reminders from share point list calendar shared in Outlook Using Outlook 2
T populate calendar with appointments and send reminders Using Outlook 1
D Outlook for Android - Dismiss Reminders? Using Outlook 0
M flagged contacts suddenly disappeared from Reminders Using Outlook 3
A Birthday reminders now ending after 10 years?? Using Outlook 4
M Reminders or Notifications for Internet Calendars Using Outlook 1
E Meeting reminders are set for the recipient Exchange Server Administration 9
P Outlook 2013 reminders firing late, in batches Using Outlook 0
Diane Poremsky How to choose which Calendar creates reminders? Using Outlook 0
E Are reminders local or global? Using Outlook 2
D Reminders in Outlook shared calendar Using Outlook 2
Z Reminders for all members of a shared calendar Using Outlook 1
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
PSittner Email Reminders From Excel File Outlook VBA and Custom Forms 6
J Duplicate Reminders Using Outlook 5
D Add tasks to reminders and calender? Using Outlook 1
P open reminders missing after copying outlook pst file Using Outlook 2
A Calendar Reminders are Removed with Sync to Outlook.com Using Outlook.com accounts in Outlook 11
W Midnight bug - Outlook Today & reminders Using Outlook 5
H Calendar entry reminders in Outlook.com Using Outlook.com accounts in Outlook 11
C outlook 2013 task reminders vs. outlook.com task reminders Using Outlook.com accounts in Outlook 8
M suddenly cannot set outlook 2007 contact reminders Using Outlook 2
D OL 13 Reminders Using Outlook 4
J Reminders dismissed on one computer re-appear on Outlook on second computer Using Outlook 1
S No Pop Up Reminders in Outlook 2013 Using Outlook 1
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 0
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 2
M Reminders keep coming to users' calendar Exchange Server Administration 1
C shared calendar reminders Using Outlook 6
R How to avoid reminders from delegators' Calendars? Using Outlook 1
A How To Setting Multiple Reminders Using Outlook 1
S Reminders aren't showing up Using Outlook 3
G After syncing with iCould appoinmnet reminders do not show in the to-do bar Using Outlook 9
S Calender reminders question Using Outlook 13
S Reminders keep popping up, even after dismissing them Using Outlook 9
