Disappearing data from outlook calendar after using icloud-ical
Robin B
Let me start by saying...it used to be fine! But...after accepting a calendar invite from Open Table and adding to my calendar through email....all of my colored flags and data added to appointments have disappeared. I tried restoring to a previous date. I'm using Office Professional Plus but it seems like formatting is now an issue. Also odd...the weirdness only impacts from July 1st. Prior to that all of my info is intact. The info is not sitting out under other calendars....it is gone. Is there a way I can restore it?
That is really weird. It's likely you can't restore it, but I'm not sure what happened, so anything is possible.
They're gone from the items on the phone too?
In what way is formatting a problem?
Yes...info is gone from the items on my phone as well. Formatting....all of my colour coded flags have been removed and everything has been changed to rich text. It's so odd that anything that I pasted into the body of the calendar info field is gone!
W messages disappearing, not deleted Using Outlook.com accounts in Outlook 5
B disappearing original when attach to email Using Outlook 1
F some tasks are disappearing Using Outlook 4
CWM030 Rules disappearing in OL 2016? ( Yes, I searched before posting) Using Outlook 7
G Disappearing emails Using Outlook 0
M Recent emails disappearing Using Outlook 4
L Appointments disappearing Using Outlook 0
piusg 2013: Task Views keep disappearing Using Outlook 4
B Fields disappearing in folders in Outlook 2007 Using Outlook 2
M Outlook 2010 Contact Pictures Disappearing Using Outlook 3
M Tasks are disappearing in Outlook 2010 Using Outlook 4
P Outlook 2007, IMAP, and Deleted Emails (not disappearing) Using Outlook 0
D Appointments disappearing Using Outlook 2
Terry Sullivan Android Phone E-Mails Not Disappearing After Being Deleted in Outlook 2013 Using Outlook 5
G Contacts are disappearing Using Outlook 1
S Email disappearing and reappearing Using Outlook 8
R Disappearing address book Using Outlook 14
T In box meassages disappearing Using Outlook 3
R How do I keep old calendar events from disappearing? BCM (Business Contact Manager) 2
CWM330 Saving Data: Don't check certain folders Using Outlook 2
CWM330 Importing " Old Skool" Data Using Outlook 0
J Deliver new messages to New or Existing Data File? Using Outlook 2
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
V Form data not sending for some users Outlook VBA and Custom Forms 2
T Extract Data From Outlook Tasks Using Outlook 0
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
C How to export Outlook data to csv? Using Outlook 0
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
S newly added shared mailboxes downloading 500GB data a day Exchange Server Administration 1
M Outlook 2016 Requesting data from server Using Outlook 0
