Outlook 2016: Want IMAP Data Files on My D: Drive and Not C: Drive
gdeshazo54
Outlook 2016 64 bit
I recently started using Outlook 2016 for my email. I have AT&T and Outlook.com mail accounts that I want to access in Outlook on my desktop. Like some other users, my C: drive is a SSD with limited space and I want the Outlook data files to reside in an "Outlook" folder on my D: drive. I followed your instructions in the thread "Hot to move IMPA data files" when I created my initial Outlook account for my AT&T email account. Adding the "ForcePSTPath" in the registry yielded success with the Outlook data file being located in the correct folder on the D: drive. However, when I add my Outlook.com account, the corresponding data file is created on the C: drive. I understood your instructions that any accounts added AFTER the "ForcePSTPath" registry entry would default to the identified drive, but it does not. I am hoping that you might be able to shed some light on what I might be doing incorrectly.
You need to use the ForceOSTPath key for outlook.com -
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
CWM030 Outlook 2016 with imap emails keep Resurrecting themselves? Using Outlook 5
Y IMAP errors with Outlook 2016 Using Outlook 2
Liz Schneider PST from Outlook 2013 is now IMAP folders in 2016 Using Outlook 10
I Outlook 2016 and Slow access to Outlook.com IMAP Using Outlook 0
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
P Outlook 2016 Working Offline Using Outlook 2
A Outlook 2016 Outlook 2016 vs. New Outlook Using Outlook 4
M Outlook 2016 still feature updating Using Outlook 0
S Outlook 2016 and Acrobat PDFMaker Office COM Addin Using Outlook 0
W Outlook 2016 MSI - Possible to make work with O365 modern Auth & Win7? Using Outlook 4
J Outlook 2016 Trying to get Outlook 2016 to work with Office 365 Using Outlook 0
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
bhamberg Shortcuts in Folder Pane (Outlook 2016) Using Outlook 19
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
M Office 2016 Outlook is forgetting passwords Using Outlook 15
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
