In box meassages disappearing
I am using 2 computers, one lap top and one desk top. I been retrieving the mail from the laptop and and it is staying on the ISP server. Of course I can't find that setting anymore.
It looks like when I go home and down load all my mail to the desktop it removes all the mail from the server like its supposed to. But, the next time I do a send and receive from outlook on the lap top it deletes all the mail that was in my in box on the lap top.
Is there a way to set up the lap top so the mail stays in the inbox even when its not on the server?
It sounds like the laptop is configured as IMAP and the desktop is configured as pop3. Go to File, Account settings on each Outlook to check the account type.
To configure a POP3 to leave on server, go to File, Account Settings, double click on the account then click More Settings. Leave on server is on the Advanced tab. See leave on server if you need screenshots or a video tutorial
You got it. Its configured as IMAP. I'll change that and reset it to leave it on the server. thanks.
Or change the other account to use IMAP. It has some advantages, including you'll be able to sync sent items between the two Outlook's. The big drawback is that all mail is left on the server and if you have a small mailbox, you may hit your quota unless you archive mail on one computer.
A Search People>press enter box disappears. Using Outlook 3
S Default Selection For Multi-Select List Box Outlook VBA and Custom Forms 1
A GetSelectNamesDialog Pre-fill search box Outlook VBA and Custom Forms 12
P Custom Outlook form_Validations in combo box Outlook VBA and Custom Forms 0
K Sharedmail box Outlook VBA and Custom Forms 4
Diane Poremsky Outlook Suggestion Box at Uservoice Using Outlook 0
D Emails do not appear in Sent box! Using Outlook 4
Kristine RS box added in Favorites disappears Using Outlook 6
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
Ross Garvey Dialogue box opens as I exit Using Outlook 2
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
G Enter Network Password box pops up every few seconds Using Outlook 2
S Outlook form - Combo box for deciding who to send form to Using Outlook 1
V In Box Issues Using Outlook 1
S Custom yes/no message box. Using Outlook 0
L Auto-set followup/reminder popup box for ALL sent emails. Using Outlook 0
P VBA for Dialog Box when sending Email Using Outlook 8
M Send receive Progress Box Using Outlook 4
M How do I link a drop down box to a percent complete box Using Outlook 4
B In Box Empty Using Outlook 5
M details with the combo box Exchange Server Administration 3
