Sharedmail box
Kartyk
The below verbs doesnot seem to work on shared mailbox. Emails are responded through shared mailbbox but still none of the replies or forwards are captured.
EXCHIVERB_REPLYTOSENDER = 102
EXCHIVERB_REPLYTOALL = 103
EXCHIVERB_FORWARD = 104
I need the original email item and replies on the same line to make sure the reponses have been sent.
Can this be done for s shared mailbox ? PLease reply
Regards
Karthik
OK, thank you. Could you please help me with the code to find the reply item sent from shared mailbox.
This would be wonderful for the project working on.
Regards
Karthik
I have tried with many. No one understands the Shared mailbox all that well. I need a code to look through replies or forwards, from all users, sent through shared mailbox.
Could anyone please respond with the apt code ?
A Search People>press enter box disappears. Using Outlook 3
S Default Selection For Multi-Select List Box Outlook VBA and Custom Forms 1
A GetSelectNamesDialog Pre-fill search box Outlook VBA and Custom Forms 12
P Custom Outlook form_Validations in combo box Outlook VBA and Custom Forms 0
Diane Poremsky Outlook Suggestion Box at Uservoice Using Outlook 0
D Emails do not appear in Sent box! Using Outlook 4
Kristine RS box added in Favorites disappears Using Outlook 6
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
Ross Garvey Dialogue box opens as I exit Using Outlook 2
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
G Enter Network Password box pops up every few seconds Using Outlook 2
S Outlook form - Combo box for deciding who to send form to Using Outlook 1
V In Box Issues Using Outlook 1
S Custom yes/no message box. Using Outlook 0
L Auto-set followup/reminder popup box for ALL sent emails. Using Outlook 0
P VBA for Dialog Box when sending Email Using Outlook 8
M Send receive Progress Box Using Outlook 4
M How do I link a drop down box to a percent complete box Using Outlook 4
B In Box Empty Using Outlook 5
M details with the combo box Exchange Server Administration 3
L Combo Box Using Outlook 157
