Custom yes/no message box.
Scoth
Hi all,
I have a checkbox that is coded to check if certain criteria is met and if so it opens a custom meeting request. Wanted to add in if this checkbox is intentionally or mistakenly unchecked that a yes / no message box opens to see if the meeting request (would be a new request) should be resent. I can't get it to continue with the code that would send the meeting request, both yes and no seems to end the routine. Does anyone have any solutions or suggestions?
Witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
S Custom Yes/No column field Outlook VBA and Custom Forms 2
D Custom Form Overwritten? Outlook VBA and Custom Forms 20
D Custom form now unusable Outlook VBA and Custom Forms 1
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
S Adding Custom Forms Outlook VBA and Custom Forms 4
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
