Does the .fdm contain my custom form? How to make ol use it? - ol2007
john doe
Older version
Does the .fdm, attached, contain my custom form?
ol2007
- trying to avoid another hours long round of macrium-restores...
Yes, the form is in the fdm file - you install it using Manage forms - I think in Outlook 2007, it is in Tools > Options - but not sure which tab. Click Install and choose the FDM file. If you need more instructions, I will need to boot a virtual machine to check - there are too many outlook versions for my brain to remember it all. <g>
tools > forms > choose a form
...lets me see/design the one ol is currently using (corrupt!) - but it doesn't let me import a file.
thank you, diane. i'm now sorted re: the form - but now ol-search is giving me trouble. see another thread...
e_a_g_l_e_p_i Why does MS do these things???? Using Outlook 4
Witzker Outlook 2019 Edit contact from email does not open the user defined contactform Using Outlook 3
J Event/Meeting in Outlook Does Not Align with SharePoint Calendar Using Outlook 5
C Why does Outlook (desktop) 365 for Windows keep making me input my passwords? Using Outlook 12
J WshShell.Popup does't timeout Outlook VBA and Custom Forms 3
L Does this really work and get thru virus and malware blocks? Using Outlook 3
N Free/busy publish at http location does not work Using Outlook 0
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 3
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 0
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
E What does mean this icon at the picture attached? Using Outlook 2
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
Mark Foley Time span on WebDAV published Calendars does not appear to be working Using Outlook 7
snhnic Macro that does not overwrite but add a number Outlook VBA and Custom Forms 1
Rupert Dragwater Deleting email from Deleted Items does not work Using Outlook 0
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
G Calendar does not point to deafult data file Using Outlook 0
Diane Poremsky What does the "J" mean? Using Outlook 0
Christiaan Could not complete operation because the service provider does not support it Using Outlook 2
