How do you disable address search box when typing @ in body of email?
JaxPlanet
Outlook 2019 32-bit
When you type "@" in the body of an email in Outlook 2019, a search box opens showing your address book entries or an empty box, if nothing matches. The box completely covers what you are typing so you can't see what you are doing.
Outlook Options > Search has no effect on this feature. I unchecked all the boxes, removed Outlook from the Index, and restarted Outlook.
Please do not confuse this with Outlook.com or the Outlook Web App. This is the full desktop version of Outlook 2019. It is possible that the 365 or 2021 desktop versions have this same problem but I haven't gotten to testing them or had any customer complaints.
Please help me disable this annoying box.
Thank you in advance!
D Show this folder as an e-mail Address Book is enabled but I want to disable Using Outlook 2
A How to disable bcc option in GAL - Address Book - Exchange 2007 Exchange Server Administration 4
V How to disable Server Assisted Search Using Outlook 2
Hornblower409 Hyperlinks - Disable Auto Complete Using Outlook 0
J Hide/Disable the X button on BrowseForFolder Dialog Using Outlook 4
Y Tone Detector - How to disable Using Outlook 0
J disable Alt+S shortcut Using Outlook 21
J Hide/disable "Groups", "Shared Calendars" Using Outlook 2
G To enable/disable Allow New Time proposals Outlook VBA and Custom Forms 1
Y Disable Microsoft Outlook Test Message Using Outlook 4
U Disable "Always ask before opening" Dialog Using Outlook 3
J How do I disable advertising in Outlook 2019? Using Outlook 15
N How to disable shortcuts for Pilcrow in Outlook (Show or hide paragraph marks) Using Outlook 0
N How to disable shortcuts for Pilcrow in Outlook Using Outlook 0
P Disable Spam Notifications & Sounds Using Outlook 3
Diane Poremsky Disable Protected View for Outlook Attachments Using Outlook 0
Diane Poremsky Disable Outlook Add-ins (Apps) Using Outlook 0
J Using VBA to disable alerts / warnings Using Outlook 2
Diane Poremsky Disable the Unsafe Hyperlink Warning when Opening Attachments Using Outlook 0
N How to disable user defined fields in BCM forms Using Outlook 2
Diane Poremsky Disable Live Preview in Outlook and Word Using Outlook 0
D Preventing users to disable an Outlook Add-in Using Outlook.com accounts in Outlook 5
F Disable "Find related messages" Using Outlook 1
davecazz Anyway to disable the peek rollovers? Using Outlook 1
R Outlook Cache Mode Terminalserver disable through Registry Using Outlook 1
S Cannot disable OWA light Exchange Server Administration 5
A How to disable the pop-up “Reponses to this meeting will not be tallied." Using Outlook 0
Rupert Dragwater how to disable billingual dictionary in outlook 2010 Using Outlook 9
J How to disable syncing folder views/layouts Using Outlook 5
A Disable hotmail from Outlook email account Using Outlook 1
R Disable request to share a calendar Using Outlook 1
T Disable the To-Do Bar permanently Using Outlook 15
D Disable Junk Email in the Registry? Using Outlook 8
P disable image compression Using Outlook 5
E Disable outlook 2010 no-subject warning Using Outlook 9
C Disable printing Outlook VBA and Custom Forms 1
A disable a menu in active inspector Outlook VBA and Custom Forms 1
