Send receive Progress Box
MJB
Outlook 2013 64 bit
Outlook 2013 The send receive progress box content disappears and in calendar the content of a date I click on also disappears. I have done a format reinstall of both Windows 8 and Office 2013 which solved the problem. It has suddenly reappeared with no changes to the computer. Microsoft point to graphics but Nvidia have no solutions. Microsoft have been unable to fix it and say it is new to them.
In Outlook's file, Options, Advanced menu, disable Hardware graphics acceleration. See if that helps.
I have disabled acceleration in both Outlook and via the Nvidia software. I have also reinstalled both Win 8 (format) and Office 2013. This initially solved the problem. I then reinstalled software one at a time after ensuring compatibility for each program with Win 8. I checked after each install without problem recurring. This worked until after 5 days from the last install it suddenly started again. No changes to software or settings prompted it. PS Are you really one person if so where do you get your energy?
I am one person and if you notice, it took 2 days to reply, so not much energy here. :)
Were any updates installed right before it stopped working again?
That's the problem. Nothing other than running programs was done. I thought it had been solved. The one clue is that alternate dates (mouse clicks) disappear from the calendar. The others remain. Also the disappearing progress content box also varies. If I run it twice it usually stays the second time. As it does not affect anything else including Excel and Word it looks like one of the Outlook settings? If so I can't find it. PS 2 days over Easter is an excellent response time and it is good of you to help so many people.
S Send/Receive Progress is black??? Using Outlook 4
K Send/Receive All Folders doesn't show Progress status Using Outlook 14
J Send/Receive Stuck Exchange Server Administration 4
P Removing Outlook 365 Account from Send/Receive Using Outlook 3
E FUNCTION SEND/RECEIVE OUTLLOK AND VB6 Outlook VBA and Custom Forms 3
L How to automaticlly Send/Receive every 3 mins but override send if send/receive is pressed Using Outlook 2
Diane Poremsky Configuring a Manual Send and Receive in Outlook Using Outlook 0
M configure Onpremise exchange to send/receive emails internally and externally) Exchange Server Administration 0
P Outlook 2007 not sending/receiving until restart (send/receive stuck at __%) Using Outlook 27
J Send and Receive Button - only check default account? Using Outlook 1
S send/receive issues outlook 2013 Using Outlook 4
W OUTLOOK 2007 FREEZES. WILL NOT SEND NOR RECEIVE Using Outlook 1
Z Always Send from Default Account, depend of receive account Outlook VBA and Custom Forms 7
wisedave Office 365 Outlook - Emails send but don't receive Using Outlook 12
D Outlook 2010 hangs during message send/receive Using Outlook 2
Nesher Can send but not receive Using Outlook 1
David Trevose Hanging on Send Receive Using Outlook 2
mikecox "Send/Receive" goes missing Using Outlook 3
R Email Send & Receive Turned off but sends automatically anyway Using Outlook 1
N Outlook 2010 take long time in send / receive Using Outlook 1
J why won't the automatic send/receive work Using Outlook 7
A Auto send-receive in Outlook not working Using Outlook 6
R send/receive no action Using Outlook 2
A yahoo mail doesn't send or receive reliably Using Outlook 1
E Strange Send/Receive count Using Outlook 3
Jennifer Murphy Why would I want to send/receive when offline? Using Outlook 0
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
A Send only, don't receive Using Outlook 1
H Send/Receive Error Sending E-Mails Using POP3 GMail Account Using Outlook 2
J Correct settings for send/receive groups w/Exchange Using Outlook 3
T Changed password now can't send/receive Using Outlook 1
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
J Send/receive getting stuck Using Outlook.com accounts in Outlook 1
X Send & receive takes SO LONG Using Outlook 1
P Send/Receive error in Outlook 2007 Using Outlook 2
W Send/Receive status bar Using Outlook 0
O two profiles send/receive from different servers Using Outlook 1
S Error code 0x8004102A Error With Send/Receive Using Outlook.com accounts in Outlook 2
