Why would I want to send/receive when offline?
Jennifer Murphy
Outlook 2016 64 bit
I am puzzled about the Send/Receive options that take effect when Outlook is offline?
Why would I want to connect to the server if I have put Outlook offline?
When is the downside of turning these two options (F9 and automatic) off and leaving them off? If I want to get messages, I go back online? No?
This is for a POP3 account.
J Send/Receive Stuck Exchange Server Administration 4
P Removing Outlook 365 Account from Send/Receive Using Outlook 3
E FUNCTION SEND/RECEIVE OUTLLOK AND VB6 Outlook VBA and Custom Forms 3
L How to automaticlly Send/Receive every 3 mins but override send if send/receive is pressed Using Outlook 2
Diane Poremsky Configuring a Manual Send and Receive in Outlook Using Outlook 0
M configure Onpremise exchange to send/receive emails internally and externally) Exchange Server Administration 0
P Outlook 2007 not sending/receiving until restart (send/receive stuck at __%) Using Outlook 27
J Send and Receive Button - only check default account? Using Outlook 1
S send/receive issues outlook 2013 Using Outlook 4
W OUTLOOK 2007 FREEZES. WILL NOT SEND NOR RECEIVE Using Outlook 1
Z Always Send from Default Account, depend of receive account Outlook VBA and Custom Forms 7
wisedave Office 365 Outlook - Emails send but don't receive Using Outlook 12
D Outlook 2010 hangs during message send/receive Using Outlook 2
Nesher Can send but not receive Using Outlook 1
David Trevose Hanging on Send Receive Using Outlook 2
mikecox "Send/Receive" goes missing Using Outlook 3
R Email Send & Receive Turned off but sends automatically anyway Using Outlook 1
N Outlook 2010 take long time in send / receive Using Outlook 1
J why won't the automatic send/receive work Using Outlook 7
A Auto send-receive in Outlook not working Using Outlook 6
R send/receive no action Using Outlook 2
A yahoo mail doesn't send or receive reliably Using Outlook 1
E Strange Send/Receive count Using Outlook 3
S Send/Receive Progress is black??? Using Outlook 4
M Send receive Progress Box Using Outlook 4
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
A Send only, don't receive Using Outlook 1
K Send/Receive All Folders doesn't show Progress status Using Outlook 14
H Send/Receive Error Sending E-Mails Using POP3 GMail Account Using Outlook 2
J Correct settings for send/receive groups w/Exchange Using Outlook 3
T Changed password now can't send/receive Using Outlook 1
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
J Send/receive getting stuck Using Outlook.com accounts in Outlook 1
X Send & receive takes SO LONG Using Outlook 1
P Send/Receive error in Outlook 2007 Using Outlook 2
W Send/Receive status bar Using Outlook 0
O two profiles send/receive from different servers Using Outlook 1
S Error code 0x8004102A Error With Send/Receive Using Outlook.com accounts in Outlook 2
