"Send/Receive" goes missing
mikecox
I often find Send/Receive missing from the toolbar, when that happens I use F9. For a long time I thought I had just forgotten where the option was. But then, later, I discover it right where I expected to be when it was missing.
It goes missing from the ribbon. In fact it is more often missing than present; like right now. It will probably re-appear at some point; later in the day.
I thought maybe it would show up when I hit Reply, but it doesn't. Right now, if I try to post a message my only option is to use F9.
Go into File, Options, Customize ribbon - if you customized the ribbon you may want to export it first, then Reset it. If it sticks around, the ribbon was corrupt. If it keeps acting up, something else is the problem and you can restore the exported ribbon customization if you exported it.
Try Safe mode - it's possible an addin or a support file is causing problems.
J Send/Receive Stuck Exchange Server Administration 4
P Removing Outlook 365 Account from Send/Receive Using Outlook 3
E FUNCTION SEND/RECEIVE OUTLLOK AND VB6 Outlook VBA and Custom Forms 3
L How to automaticlly Send/Receive every 3 mins but override send if send/receive is pressed Using Outlook 2
Diane Poremsky Configuring a Manual Send and Receive in Outlook Using Outlook 0
M configure Onpremise exchange to send/receive emails internally and externally) Exchange Server Administration 0
P Outlook 2007 not sending/receiving until restart (send/receive stuck at __%) Using Outlook 27
J Send and Receive Button - only check default account? Using Outlook 1
S send/receive issues outlook 2013 Using Outlook 4
W OUTLOOK 2007 FREEZES. WILL NOT SEND NOR RECEIVE Using Outlook 1
Z Always Send from Default Account, depend of receive account Outlook VBA and Custom Forms 7
wisedave Office 365 Outlook - Emails send but don't receive Using Outlook 12
D Outlook 2010 hangs during message send/receive Using Outlook 2
Nesher Can send but not receive Using Outlook 1
David Trevose Hanging on Send Receive Using Outlook 2
R Email Send & Receive Turned off but sends automatically anyway Using Outlook 1
N Outlook 2010 take long time in send / receive Using Outlook 1
J why won't the automatic send/receive work Using Outlook 7
A Auto send-receive in Outlook not working Using Outlook 6
R send/receive no action Using Outlook 2
A yahoo mail doesn't send or receive reliably Using Outlook 1
E Strange Send/Receive count Using Outlook 3
Jennifer Murphy Why would I want to send/receive when offline? Using Outlook 0
S Send/Receive Progress is black??? Using Outlook 4
M Send receive Progress Box Using Outlook 4
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
A Send only, don't receive Using Outlook 1
K Send/Receive All Folders doesn't show Progress status Using Outlook 14
H Send/Receive Error Sending E-Mails Using POP3 GMail Account Using Outlook 2
J Correct settings for send/receive groups w/Exchange Using Outlook 3
T Changed password now can't send/receive Using Outlook 1
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
J Send/receive getting stuck Using Outlook.com accounts in Outlook 1
X Send & receive takes SO LONG Using Outlook 1
P Send/Receive error in Outlook 2007 Using Outlook 2
W Send/Receive status bar Using Outlook 0
O two profiles send/receive from different servers Using Outlook 1
S Error code 0x8004102A Error With Send/Receive Using Outlook.com accounts in Outlook 2
