Change settings Send/receive VBA
Aleixa
Outlook 2019 64-bit
I have several email accounts that you used with Outlook POP. Various of gmail. And I travel a lot.
Now, GMail, every time I change country, or even city, blocks it and asks for confirmation through the browser.
It becomes necessary to open each GMail account in the Browser and confirm that it is me that I am accessing from a different place...
So, I made several groups of sending/receiving emails. One with all the accounts I use (more than 15), the other with only 4, to access when I'm traveling for a few days.
I wish I didn't have to do this by entering the settings
Settings > Advanced > Send/Receive > ...
and change which shipping group will be used.
But I can't find the VBA code to access the settings anywhere
and the send/receive groups.
It's possible?
Aleixa
Translated with google
M Change default "automatically test account settings when Next is clicked" Using Outlook 1
M Default settings for "Display as" Change? Outlook VBA and Custom Forms 8
W frustrating trying to change email password Using Outlook 5
R Outlook 2021 change view Using Outlook 2
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
C Mass Change Selected Contact Photos Outlook VBA and Custom Forms 1
D Unable to change AppointmentItem.Start property Outlook VBA and Custom Forms 3
sjmo2 Change subject for new e-mails only. Outlook VBA and Custom Forms 2
Horsepower Contact phone numbers randomly change Using Outlook 0
P Outlook 2016 Change Paste Special Default Format Using Outlook 8
whizzard Change FROM address based on TO or CC address Outlook VBA and Custom Forms 8
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
V Can one change the formatting of email title blocks? Using Outlook 0
S Unable to change Message Class Outlook VBA and Custom Forms 0
C Outlook 365 Can you change the follow up colour? Using Outlook 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
Witzker HowTo Change message Class of contact form Outlook VBA and Custom Forms 0
R How to Change Margins In Google Docs...? Using Outlook 0
D Change senders title Using Outlook 1
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
B Change from Address Outlook VBA and Custom Forms 0
X If you change expiration date of repeated task it dupplicates Using Outlook 1
R Folder pane width change Using Outlook 90
P How can I change my calendar view back Using Outlook 3
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
geofferyh How to change the Attachment File Name? Outlook VBA and Custom Forms 1
