Quick Parts - font changes
dfin
Sometimes when replying to emails in Outlook 2010 using Quick Parts, the font of the Quick Part text changes.
For example, the Quick Parts were setup as Calibri, but they sometimes paste into the reply as TimeNew Roman.
Looking at the HTML source of the message, this seems to happen when the original message has MsoNormal setup with Times as it's font.
Is there a way to avoid the font change?
Dave
larry
I'm not aware of any tricks you can use to avoid the font change. Do you get the paste button when you use quick parts? If so, you can choose source formatting. Actually, check your default paste settings. Using source formatting might do it.
dfin
Changing to source formatting didn't make a difference - thanks for the idea, though.
larry
Darn, I hoped that would work. Are you pasting in the middle of sentences or as new paragraphs?
dfin
It's typing in a greeting at the top of the reply. hitting enter, the pasting in the quick part. The greeting typed manually is in Calibri, but the quick part changes to Times.
That sounds an awful lot like the last line problem we see with signatures - the last paragraph mark in a message may not be styled like the signature.
What font is your default for messages? Is it assigned to the +Body style?
I'll try to repro it - I'm pretty sure its something goofy with styles. Word has some well known problems copying and pasting - whether the style is kept depends on copying the paragragh mark. It's caused a lot of grief for a lot of users over the years and with Outlook using the word editor, the problems followed.
Ok... i think i might have repro'd it. I have times set as the +Body style but changed the font in Stationery and Fonts to comic sans. When I insert a QP created using 'insert text only', it uses the +Body style, not the font assigned in Fonts. When i insert a QP saved using 'insert in own para.' it saved the style (font= baskerville) assigned to the text and uses it.
I'm still trying to figure 'text only' QP out - in one case it seemed to use the Body style, but in another, it kept the font i used when i created it.
M font format discrepancies with Quick Parts Using Outlook 1
D Quick Parts - font changes Using Outlook 0
C Quick Parts signatures suddenly require more letters Using Outlook 2
B Push Quick Parts to All Users Using Outlook 1
S Inserting Dates With Quick Parts (or Macros) Using Outlook 4
S Quick Parts - Changing Display and Order Using Outlook 0
J Text icon in Quick Access toolbar ? Using Outlook 2
Ken Pascoe Outlook Categories Quick List Using Outlook 0
Diane Poremsky Synchronize Quick Access Toolbar and Ribbons? Using Outlook 0
S Save in folder other than Sent when replying with Quick Steps Using Outlook 5
R Missing Quick Steps and Rules Using Outlook 0
A Quick Steps in Tasks view Using Outlook 7
J quick quesiton about outlook search Using Outlook 3
iwshim Skype tool bar in quick access ribon Using Outlook 1
B How can I adjust the ribbon width? I want to see all of my Quick Steps. Using Outlook 1
L Quick step to fill custom field Outlook VBA and Custom Forms 1
adaminaus Quick question if i may Using Outlook 4
C Further automate several tasks with rule, VBA or Quick Step Using Outlook 1
L Outlook Data Files command not working in the quick access bar Using Outlook 1
S New Quick Step based on Team email QS - automatically update too Using Outlook 1
L Outlook 2010 Quick Print Attachment, nothing happend Using Outlook 0
B quick help with "changed by" field in a shared mailbox?? Using Outlook 3
A Recommend add-on or utility enabling quick Google search within Outlook Using Outlook 7
J Outlook 2010 using Quick Print to print attachments Using Outlook 1
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
S Quick Search will not work due to itemizing Using Outlook 1
E Blank Print Preview when access via the Quick Access toolbar Using Outlook 3
D How do I get a new mail icon into my quick launch bar? Using Outlook 3
K Quick Print shows wrong date on Occurrences Using Outlook 1
I Office 2010 Quick Steps Using Outlook 10
T Quick Access Toolbar Using Outlook 3
S Quick access toolbar in inspector window Outlook VBA and Custom Forms 3
V Parts of Outlook UI transparent Using Outlook 2
