Outlook hanging issue
phartshorne
Outlook 2013 64 bit
Exchange Server 2013
We are currently experiencing an issue whereby a small number of our users are experiencing Outlook freezing, seemingly at random several times a day.
It can happen at anytime, when composing mail, clicking between folders or even when Outlook is not in use and just sat idle. Symptoms are always the same, Outlook doesn’t respond for a few seconds then goes back to normal. Obviously this is quite frustrating especially when composing a mail.
We run Exchange 2013 and the majority of our users are using Outlook 2010 connected in cached mode, however we have had the issue on Outlook 2013 and in online mode. We have a cross forest 2 way trust between our old and new domains, but the problem affects people logging into either domain (Exchange is in the new domain). Our Exchange environment is running fine, and there is no correlation between the users and the mailbox database they are on/any additional mailboxes they access.
The problem does seem to follow the user, new Outlook/Windows profiles, re-imaging the PC or even proving a brand new PC with only Windows and Office installed haven't resolved it.
We've tried everything here - https://support.microsoft.com/en-us/kb/2652320 as well as several other fixes, including disabling hardware acceleration and this has had some success but the problem generally re-occurs after a short period of time.
Any ideas/suggestions would be gratefully received.
Many thanks
Paul Hartshorne
W Outlook 2021 Hanging on "Sending Emails" Using Outlook 3
J Outlook 2013 hanging for unknown reason Using Outlook 1
S Volunteer request: opening invented MSG files in Outlook for Windows Using Outlook 0
A How to Convert an Orphaned OST File Without Outlook or Exchange? Using Outlook 3
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 6
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 5
B Sync Google Calendar with Outlook Using Outlook 5
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
W New Outlook PEOPLE blank Using Outlook 6
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
