Task Recurrence Settings
Commander1
Outlook 2013 64 bit
I can set a task recurrence but if I want to remove that recurrence setting I am unable to do so because the relevant button is "greyed out". This means that whatever I do with the task, even deleting it, it keeps re-occurring. If I delete the task, I don't see the option of deleting only a single occurrence or all occurrences.
The only way out of this useless cycle is by setting the recurrence to one day, limiting it to one occurrence and then deleting the task.
Is this strange behaviour known, or is it possible unique to my installation?
does anyone else experience this and i fso is there a solution?
That is not normal behavior, or you aren't deleting it correctly. is the task in your POP3 pst file? Is it syncing with anything? (It's possible the synced copy isn't getting deleted and is resyncing.)
Select and deleting the recurring copy should delete the task completely - you should be offered to delete this one or all (but not previous occurrences already marked complete). You can end it early by clicking Recurrence button then changing the end date. Remove recurrence should also end it and leave just a single non-recurring task.
C Outlook 2013 Task Recurrence - Third Friday After the Second Tuesday Using Outlook 2
G Arggh, weakness of reminder for every Task recurrence Using Outlook 0
K Daily Task List Minimized Cannot Display Using Outlook 5
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 4
S Outlook 2016 Understand and customize prepended behavior of recurring task Using Outlook 0
K Multiple copies of task being created Using Outlook 2
P Short Date Format when typing in a task Using Outlook 2
P Task display now leaves little room for notes Using Outlook 10
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
D How To Combine Share Task Folders in just one Folder Using Outlook 0
P Can't paste an image into a task Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
T Report For Task Recurrance Outlook VBA and Custom Forms 4
E Can't accept or decline task (no button appears) Using Outlook 2
X If you change expiration date of repeated task it dupplicates Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
Z VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
M Daily Task List Minimized Cannot Display Using Outlook 2
S Codes for "Mark Complete" the task Outlook VBA and Custom Forms 2
W Deleting Sent Task Email, Deletes the task from my list Using Outlook 1
K Task priority modification Using Outlook 4
F Search folder for tasks in all task folders Using Outlook 1
K outlook workflow: automated task generation Outlook VBA and Custom Forms 4
F How to assign a task to a public task folder? Using Outlook 1
copperberry How to view all tasks across task folders Using Outlook 3
P Task Categories Using Outlook 2
L Email to task without changin formatting Outlook VBA and Custom Forms 16
P Custom form reverts from task Outlook VBA and Custom Forms 1
evdbogaard How to dock the Styles Task Pane in the e-mail editing window? Outlook VBA and Custom Forms 1
S Default Font in body of Task Using Outlook 0
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
