My VSTO 3.0 Outlook addin doesn’t load
  • Thread starter Thread starter Wayne
W
Wayne
[Sorry if this isn't the right forum for this... technically not VBA but this
is the closet forum I could find]
I'm trying to diagnose why my Outlook plugin written in C#/VSTO 3.0/VS 2008
doesn't load after being installed.
The plugin works awesomely on my development machine, which has Visual
Studio 2008 installed. I can't expect all my users to have all the
prerequisites though so I went through these steps to write an installer:
http://msdn.microsoft.com/en-us/library/cc563937(loband).aspx
I installed the add-in on a fresh Windows XP SP 2 machine with a fresh
install of Outlook 2007. It installs all the prereqs ok (.NET 3.5, VSTO 3.0
runtime, Windows Installer 3.1, 2007 PIAs). Outlook starts but the add-in
isn't run. If I go to the Add-ins tab in the Trust Center, I see my add-in in
the "Inactive Application Add-ins" section with the message "Not loaded. A
runtime error occurred during the loading of the COM Add-in.".
Not sure how to find the specific error so I can fix it.
The reg keys look ok. Under
HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\Addins\BlahAddin I see
Description, FriendlyName, LoadBehavior (set to 3 until it fails after which
if becomes set to 2), and Manifest.
Tried the VSTO_SUPPRESSDISPLAYALERTS environment variable trick and then
launched Outlook from the command line but no output came out.
I have remote debugging more or less working but I'm not sure what to look
for. I don't see my DLL loaded when I attach to Outlook, but then again maybe
managed DLLs don't show up the same way in VS.
Any other ideas on next steps I could follow to produce a specific error I
can diagnose?
(Cross-posted to Stack Overflow, but still haven't figured this out:
http://stackoverflow.com/questions/1330282/my-vsto-3-0-outlook-addin-doesnt-load )
Re: My VSTO 3.0 Outlook addin doesn’t load
Did you set the security? Without full trust a VSTO addin won't run.
If you did that and see the trust settings in the Framework configuration
tool you'd probably need to use Fusion logging and to study the logs to see
what's failing (Fusion is the managed code loader).
See
http://blogs.msdn.com/vsod/archive/2008/04/22/Troubleshooting-com-add-in-load-failures.aspx
There's also a managed forum specific to VSTO at the MSDN forums.
"Wayne" <Wayne> wrote in message
news:548727E5-5D76-42AC-A09E-CDED05868D50@microsoft.com...
> this
> 2008
> 3.0
> in
> which
> maybe
> can diagnose?
> Thanks!
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
M c# vsto Outlook.ApplicationEvents_11_NewMailEx Outlook VBA and Custom Forms 1
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
O VSTO - Outlook Add-In - Get GAL data Outlook VBA and Custom Forms 1
K Outlook VSTO Add-in not visible in Trust Center after installing Outlook VBA and Custom Forms 1
M Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010? Outlook VBA and Custom Forms 1
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
O Outlook VSTO 2005 plug-in installer: CLSID = ? Outlook VBA and Custom Forms 3
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
M VSTO deployment? Outlook VBA and Custom Forms 1
M VSTO C#: How do I declare an application scope variable? Outlook VBA and Custom Forms 2
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
G Interop or VSTO or ? Outlook VBA and Custom Forms 2
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
O using VSTO to get Available Mailboxes Outlook VBA and Custom Forms 11
M VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp Outlook VBA and Custom Forms 1
C Problem installing VSTO AddIn on Vista Outlook VBA and Custom Forms 3
G Data Left Behind when Migrating To Outlook from Thunderbird - Insights on the Issue Using Outlook 0
V Outlook spam filter misbehaving Using Outlook 5
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
W New Outlook PEOPLE blank Using Outlook 6
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 3
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 4
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 7
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
