Outlook VSTO Add-in not visible in Trust Center after installing
  • Thread starter Thread starter Koen Verwimp
K
Koen Verwimp
I have implemented a VSTO Outlook Add-in and created a setup project.
When I install this add-in project with the setup/msi file ... files are
installed properly, but VSTO Add-in isn't visible in the trust center of
Outlook.
This is because the registry keys are missing at
[HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\Addins\ProjecT_name].
When I add the correct registry values manualy, it works fine.
What do i need to change/add to my Visual Studio 2008 setup project, for
automatically adding the registry keys for my VSTO Add-In?
What is missing in the VS setup project?
regards,
Koen V
You obviously need to add registration. You also might need to add full
trust on the VSTO addin dll, otherwise it won't run even if registered.
You don't mention anything about your setup such as VSTO version, Outlook
version, VS version, so one can only guess at things. But you might want to
look at the deployment information at
http://msdn.microsoft.com/en-us/library/aa537173(office.11).aspx. There are
versions of the article for other VSTO versions also.
"Koen Verwimp" <KoenVerwimp> wrote in message
news:31B4A45F-8FB9-47B5-910B-16DACEE9B9DA@microsoft.com...
> Hi,
> Outlook.
> regards,
> Koen V
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
O VSTO - Outlook Add-In - Get GAL data Outlook VBA and Custom Forms 1
M Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010? Outlook VBA and Custom Forms 1
M c# vsto Outlook.ApplicationEvents_11_NewMailEx Outlook VBA and Custom Forms 1
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
O Outlook VSTO 2005 plug-in installer: CLSID = ? Outlook VBA and Custom Forms 3
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 3
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
