Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010?
  • Thread starter Thread starter Mark B
Mark B
Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010 (without having to
make any code/install changes)?
Yes.
"Mark B" <none123@none.com> wrote in message
news:eQw0ytXbKHA.2572@TK2MSFTNGP05.phx.gbl...
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
M c# vsto Outlook.ApplicationEvents_11_NewMailEx Outlook VBA and Custom Forms 1
O VSTO - Outlook Add-In - Get GAL data Outlook VBA and Custom Forms 1
K Outlook VSTO Add-in not visible in Trust Center after installing Outlook VBA and Custom Forms 1
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
O Outlook VSTO 2005 plug-in installer: CLSID = ? Outlook VBA and Custom Forms 3
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
M VSTO deployment? Outlook VBA and Custom Forms 1
M VSTO C#: How do I declare an application scope variable? Outlook VBA and Custom Forms 2
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
G Interop or VSTO or ? Outlook VBA and Custom Forms 2
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
O using VSTO to get Available Mailboxes Outlook VBA and Custom Forms 11
M VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp Outlook VBA and Custom Forms 1
C Problem installing VSTO AddIn on Vista Outlook VBA and Custom Forms 3
T Support ending for Outlook 2021 Using Outlook 3
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 3
