VSTO 2007 Addin auto-disabled on one machine but not another on installation?
  • Thread starter Thread starter Mark B
Mark B
Our VSTO 2007 Addin is being immediately auto-disabled on one machine but
not another on installation.
Anyone know why this would be?
What's different on the 2 machines? Are you deploying all required
dependencies of your addin (including the VSTO runtime and Framework, the
Office and Outlook PIA's, etc.)?
Take a look at the following troubleshooting information for managed code
addins:
http://blogs.msdn.com/vsod/archive/2008/04/22/Troubleshooting-com-add-in-load-failures.aspx
"Mark B" <none123@none.com> wrote in message
news:e8IoG0qDKHA.4608@TK2MSFTNGP02.phx.gbl...
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
M Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010? Outlook VBA and Custom Forms 1
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
M c# vsto Outlook.ApplicationEvents_11_NewMailEx Outlook VBA and Custom Forms 1
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
O VSTO - Outlook Add-In - Get GAL data Outlook VBA and Custom Forms 1
M VSTO deployment? Outlook VBA and Custom Forms 1
K Outlook VSTO Add-in not visible in Trust Center after installing Outlook VBA and Custom Forms 1
M VSTO C#: How do I declare an application scope variable? Outlook VBA and Custom Forms 2
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
G Interop or VSTO or ? Outlook VBA and Custom Forms 2
O Outlook VSTO 2005 plug-in installer: CLSID = ? Outlook VBA and Custom Forms 3
O using VSTO to get Available Mailboxes Outlook VBA and Custom Forms 11
M VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp Outlook VBA and Custom Forms 1
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
C Problem installing VSTO AddIn on Vista Outlook VBA and Custom Forms 3
B Outllok 2007 License Expired issue Using Outlook 0
