VSTO Outlook add-in: Categories not displaying correctly
  • Thread starter Thread starter TTT
TTT
An Outlook add-in is not working correctly on a client site.
The add-in should change the Categories of an Inbox email. We want the Categories to change to "Reg'd" when the user registers an Inbox email to our database via the add-in.
On a particular clients machine, this will work OK if the email has been opened, but will not make any change to the Categories if the email hasn't been opened, just selected and right clicked to access the add-in menu. In all cases, the email has been properly sent to the database. I am pretty sure the line of code to update Categories is being called in all instances.
I can't reproduce this error to debug on my machine, where Categories updates correctly in all cases.
All machines are on 2003 SP 3. The client is operating outlook via terminal services. Could this cause problems?
What can cause the Categories column to not update correctly in cases like this?.
It's certainly possible that terminal services has something to do with it,
but I don't see how. If your code is modifying specific items the category
is being added as a one-off on the items. So it shouldn't matter if the
category is in the master list as a custom category or not (those are stored
in the registry for Outlook 2003).
That it works when the change is made to an Inspector but not in an Explorer
context menu would also tend to indicate that TS has nothing to do with it,
the end result would be the same in either case.
I would add additional logging to see if the code is actually hit and does
run without exceptions. I'd also see what's different on that user's machine
than on others where the code runs. Addins and any other code that
interfaces with Outlook should be checked and disabled to see if they have
any effect.
"TTT" <alistair[at]timetracer[dot]com[dot]au> wrote in message
news:uTX4iBg1KHA.264@TK2MSFTNGP05.phx.gbl...
> An Outlook add-in is not working correctly on a client site. The add-in
> via the add-in.
> instances.
> this?.
I have found a related problem that I can reproduce. I think if I can fix this it may fix the original problem.
When I select multiple emails and register them to our database, only the first one selected has its Category changed to Reg'd. The others' behaviour depends on what mail server I am running. If I am on a POP account, the Category does not change. On a Microsoft Exchange Server at first the "Reg'd" doesn't show, but if I click on the email and then off, it appears.
The code is effectively like this, with my logging added to double check that the correct string is going in.
foreach (Outlook.MailItem mailItem in _emails)
mailItem.Save();
// Add the registered category to the mail item
CategoryHelper.AddCategory(mailItem, EmailManager.RegCategory);
MessageBox.Show(mailItem.Categories);
//We have to save the email if the properties are to stay.
mailItem.Save();
If I run this with two emails selected the following happens
MessageBox Reg'd
The first email Category changes to Reg'd
MessageBox Reg'd
MessageBox Reg'd
No change in second email
MessageBox Reg'd
So the Save works for the first email, but not the second.
Any explanations?
> kenslovak wrote on Wed, 07 April 2010 09:22
> but I don't see how. .
I have no explanation for that and I've never seen anything like that
happen. Offhand the code looks OK but I have no idea what that helper is
doing or if it might cause an exception that might prevent adding a
category.
news:uu0ixg71KHA.5880@TK2MSFTNGP05.phx.gbl...
> it appears.
> mailItem.Save();
> to stay.
> mailItem.Save();
> MessageBox Reg'd
> MessageBox Reg'd
> MessageBox Reg'd
> MessageBox Reg'd
> Any explanations?
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
O VSTO - Outlook Add-In - Get GAL data Outlook VBA and Custom Forms 1
K Outlook VSTO Add-in not visible in Trust Center after installing Outlook VBA and Custom Forms 1
M Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010? Outlook VBA and Custom Forms 1
M c# vsto Outlook.ApplicationEvents_11_NewMailEx Outlook VBA and Custom Forms 1
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
O Outlook VSTO 2005 plug-in installer: CLSID = ? Outlook VBA and Custom Forms 3
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
M VSTO deployment? Outlook VBA and Custom Forms 1
M VSTO C#: How do I declare an application scope variable? Outlook VBA and Custom Forms 2
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
G Interop or VSTO or ? Outlook VBA and Custom Forms 2
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
O using VSTO to get Available Mailboxes Outlook VBA and Custom Forms 11
M VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp Outlook VBA and Custom Forms 1
C Problem installing VSTO AddIn on Vista Outlook VBA and Custom Forms 3
C Best way to keep clinic quotes organized in Outlook? Using Outlook 1
S Same POP account on Outlook 2024 and Outlook Classic ? Using Outlook 16
S Outlook Classic Rules Using Outlook 3
G Keeping Outlook Classic (desktop) PST in Google Drive folder? Using Outlook 4
T How to fix disconnected Outlook account Using Outlook 6
F Outlook Data File Column Empty Using Outlook 3
C Multiple accounts on Outlook.com? Using Outlook 3
