Automating Outlook 2007 problem with sending mail
  • Thread starter Thread starter Norm
N
Norm
I hope this is the right newsgroup to ask this in. I have an application
written in Visual Basic 6 SP6 that automates Outlook. It has worked fine
until I upgraded to Outlook 2007 and for some reason it will not resolve the
names correctly. So I am assuming that something has changed and the code as
written will no longer work. The code I am using is pasted below and hope
that someone can spot what needs to be changed for Outlook 2007.
Norm
Do
bCheck = False
sPath = CStr(i)
MyReport = sGetINI(AppPath & "\ProgramIni\Supervisor Logs.ini",
"Path", sPath, Default)
If MyReport = "" Or MyReport = "0" Then Exit Do
oMail.Recipients.ADD MyReport
bCheck = oMail.Recipients.ResolveAll-----This line is the problem,
bCheck will remain false even on a good address.
If Not bCheck Then
AllReports2 = MyPath2 & MyReport
MyPath2 = AllReports2 & ";"
GoTo Skip1
AllReports = MyPath & MyReport
MyPath = AllReports & ";"
Skip1:
Set objMailitem = Nothing
i = (i + 1)
Loop
Well the code is working now. Not sure what happened, but it started working
this evening, without changing anything. Guess I don't need any help at the
moment. :-)
Thanks anyway,
Norm
"Norm" <NormF4@newsgroups.nospam> wrote in message
news:F0DB9F21-4B05-4885-801C-0B79BC921168@microsoft.com...
> Hi,
> the names correctly. So I am assuming that something has changed and the
> code as written will no longer work. The code I am using is pasted below
> and hope that someone can spot what needs to be changed for Outlook 2007.
> Thanks,
> Norm
> Do
> bCheck = False
> sPath = CStr(i)
> If Not bCheck Then
> GoTo Skip1
> End If
> Skip1:
> i = (i + 1)
> Loop
S Outlook 2007: automating form with macro Outlook VBA and Custom Forms 2
R Automating from excel into shared Calendars Using Outlook 1
C Automating subject line Using Outlook 1
L automating a BCC on every email Using Outlook 1
T Automating Exporting to pst file Outlook VBA and Custom Forms 3
J Automating Word from script Outlook VBA and Custom Forms 8
S Automating the selection of email accounts upon adding email addre Outlook VBA and Custom Forms 1
L new outlook contacts searching Using Outlook 2
W New Outlook PEOPLE blank Using Outlook 7
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 4
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 6
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 22
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
