Automating Word from script
Joel Allen
Outlook 2003 SP3
I currently automate a Word document via my script from my custom outlook
task. I use bookmarks and it works great.
However, now I have a need now to insert tables, change font size, etc.....
I'm having trouble with the basics like trying to insert text into a certain
cell then tabbing to the next cell. I tried vbTab but no luck.
Does anybody have a good reference to learn from? I'm looking for sample
code and maybe sample Word files and perhaps a list of vb commmands. I'm
only aware of a few like vbTab and vbCrLf.
Thank you very much,
Joel
K
Ken Slovak - [MVP - Outlook]
A good Word programming book might help. The Word MVPs have a Web site that
has a lot of information and code samples at http://word.mvps.org/ that
might also be helpful to you.
"Joel Allen" <joelallen123@hotmail.com> wrote in message
news:uA3AdqBIKHA.1376@TK2MSFTNGP02.phx.gbl...
> Outlook 2003 SP3
> Hi,
> etc..... I'm having trouble with the basics like trying to insert text
> into a certain cell then tabbing to the next cell. I tried vbTab but no
> luck.
> Joel
Sue Mosher [MVP]
The easiest way to get sample code is to turn on Word's macro recorder as
you perform the tasks you want to accomplish. Then, look at the macro, see
what objects are are involved, check out their methods, etc.
Sue Mosher
> Outlook 2003 SP3
> Hi,
> luck.
> Joel
Joel Allen
Thank you Sue. I think this will help a lot.
Now, I started simple with this:
Selection.Font.Name = "Calibri"
and
objDoc.Selection.Font.Size = 11
Neither work. I think I need to set some variables or something. Do you
have some sample code of that? I think if I can get that far, I can take it
on my own.
Again, thanks always for your help,
Joel
"Sue Mosher [MVP]" <suemvp@turtleflock.com> wrote in message
news:%23Jvc$1CIKHA.4500@TK2MSFTNGP02.phx.gbl...
> > Sue Mosher
> > Outlook 2003 SP3
>> Hi,
> > luck.
> > Joel
Sue Mosher [MVP]
Outlook doesn't know anything about any Selection object that comes from a
Word document, so you have to add the "missing links" that indicate where
that Selection is coming from. See
http://turtleflock-ol2007.spaces.live.com/blog/cns!C1013F1F9A99E3D8!579.entry
for an example.
Sue Mosher
news:uGzXCTDIKHA.4316@TK2MSFTNGP04.phx.gbl...
> and
> it on my own.
> Joel
> > see what objects are are involved, check out their methods, etc.
> >> Outlook 2003 SP3
>>> Hi,
> >> outlook task. I use bookmarks and it works great.
> >> luck.
> >> sample code and maybe sample Word files and perhaps a list of vb
> >> commmands. I'm only aware of a few like vbTab and vbCrLf.
> >> Joel
Joel Allen
I made some progress using your blog and the macro recorder in Word. I got
selection to work with a few minor tweaks.
Now I'm trying to insert tables and format them and having really hard
time. I have to guess at the formatting. For instance, this is what the
Word macro shows:
ActiveDocument.Tables.Add Range:=Selection.Range, NumRows:=1, NumColumns:= _
5, DefaultTableBehavior:=wdWord9TableBehavior, AutoFitBehavior:= _
wdAutoFitFixed
With Selection.Tables(1)
If .Style <> "Table Grid" Then
> Style = "Table Grid"
> ApplyStyleHeadingRows = True
> ApplyStyleLastRow = True
> ApplyStyleFirstColumn = True
> ApplyStyleLastColumn = True
then I'm just trying to start simple by adding just one row of a table by
doing this in my task code:
objTable.Add Range:=objSel.Range, NumRows:=1, NumColumns:= 5
or
objTable.Rows.Add()
objSel.Range, NumRows=1, NumColumns=5
or
news:u3rPO0DIKHA.4708@TK2MSFTNGP03.phx.gbl...
> for an example.
> > Sue Mosher
> > and
> > it on my own.
> > Joel
> >> as you perform the tasks you want to accomplish. Then, look at the
> >> macro, see what objects are are involved, check out their methods, etc.
> >>> Outlook 2003 SP3
>>>> Hi,
> >>> no luck.
> >>> Joel
Joel Allen
selection to work with a few minor tweaks. Works great.
Now, I'm trying to insert tables and format them and am having a really hard
Word macro shows:
wdAutoFitFixed
Then I'm just trying to start simple by adding just one row of a table by
or
objTable.Add Range=objSel.Range, NumRows=1, NumColumns= 5
or
objTable.Add Range
None of these work. It's hard to figure the conversion. Is there somewhere
where I can look at the proper format?
Thank you Sue,
Joel
> for an example.
> > Sue Mosher
> > and
> > it on my own.
> > Joel
> >>> Outlook 2003 SP3
>>>> Hi,
> >>> no luck.
> >>> Joel
Sue Mosher [MVP]
Outlook doesn't recognize ActiveDocument. So, you need a Word.Document
object; the article I suggested earlier shows how to get that from a
message.
For the sake of discussion, let's say you have a Word.Document object
variable named objDoc. As your recorded macro suggests, any Document has a
Tables collection. As with other Office objects that have an Add method,
adding a table returns the newly created Table object, e.g.:
Set newTable = objDoc.Tables.Add 'etc., using parameters like those in
your code below
Once you have the newTable object, then you can manipulate it using the
Style, ApplyStyleHeadingRows, and other properties that the macro recorder
helped you find.
Remember to use the object browser (F2 in VBA) to look up any properties and
methods you don't understand and read about them in Help, where you'll
probably find more complete examples to supplement what the macro recorder
gives you. For example, since you want to add a row to the table, the object
browser can show you that the Table object has a Rows property, which in
turn has an Add method. So you can add a new row simply with:
Set newRow = newTable.Rows.Add
Inserting text in a cell in that row looks like this:
newRow.Cells(1).Range.InsertAfter "some text"
Sue Mosher
news:eCYdRGFIKHA.1248@TK2MSFTNGP04.phx.gbl...
> hard
> Word macro shows:
> ------------------> ActiveDocument.Tables.Add Range:=Selection.Range, NumRows:=1, NumColumns:=
> _
> wdAutoFitFixed
> .Style = "Table Grid"
> End If
> .ApplyStyleHeadingRows = True
> .ApplyStyleLastRow = True
> .ApplyStyleFirstColumn = True
> .ApplyStyleLastColumn = True
> End With
> -------------> objTable.Add Range:=objSel.Range, NumRows:=1, NumColumns:= 5
> or
> or
> objTable.Add Range
> somewhere where I can look at the proper format?
> Thank you Sue,
> Joel
> > a Word document, so you have to add the "missing links" that indicate
> > where that Selection is coming from. See
> > for an example.
>> > > Sue Mosher
> >> and
> >> you have some sample code of that? I think if I can get that far, I can
> >> take it on my own.
> >> Joel
> >>>> Outlook 2003 SP3
>>>>> Hi,
> >>>> no luck.
Joel Allen
Thanks Sue. This was really helpful. Thanks for taking the time to give me
that explanation.
Joel
news:epXfjgFIKHA.2516@TK2MSFTNGP02.phx.gbl...
> message.
> your code below
> helped you find.
> and methods you don't understand and read about them in Help, where you'll
> object browser can show you that the Table object has a Rows property,
> which in turn has an Add method. So you can add a new row simply with:
> > Sue Mosher
> > hard
> > Word macro shows:
>> ------------------> > ActiveDocument.Tables.Add Range:=Selection.Range, NumRows:=1,
> > NumColumns:= _
> > wdAutoFitFixed
> > End If
> > End With
>> -------------> > objTable.Add Range:=objSel.Range, NumRows:=1, NumColumns:= 5
>> or
>> or
>> objTable.Add Range
>> Thank you Sue,
> > Joel
> >> for an example.
>>> > >> Sue Mosher
> >>> and
> >>> can take it on my own.
> >>> Joel
> >>>> etc.
> >>>>> Outlook 2003 SP3
>>>>>> Hi,
> >>>>> text into a certain cell then tabbing to the next cell. I tried
> >>>>> vbTab but no luck.
R Automating from excel into shared Calendars Using Outlook 1
C Automating subject line Using Outlook 1
L automating a BCC on every email Using Outlook 1
T Automating Exporting to pst file Outlook VBA and Custom Forms 3
N Automating Outlook 2007 problem with sending mail Outlook VBA and Custom Forms 1
S Automating the selection of email accounts upon adding email addre Outlook VBA and Custom Forms 1
S Outlook 2007: automating form with macro Outlook VBA and Custom Forms 2
V Embedding hyperlink into Word document Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
C blocking two or more word domains separated by period/dot Using Outlook 3
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
Diane Poremsky Use Word Macro to Apply Formatting to Email Using Outlook 0
iwshim word shortcut to search outlook Using Outlook 3
C Outlook 2016 - converting Word VBA to default Outlook message Outlook VBA and Custom Forms 0
C Merging Word and Access into Outlook Using Outlook 4
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
Mark Foley Emailing attachment from Word/Excel sends attachment but no message body Using Outlook 0
Diane Poremsky Disable Live Preview in Outlook and Word Using Outlook 0
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
M Unable to email from Word or Excel Using Outlook 11
P Macros in Word 2003 - how to transfer to another Word 2003? Using Outlook 1
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
B Outlook to Word Template error Using Outlook 4
J Outlook body to word document Outlook VBA and Custom Forms 11
A Application_ItemSend not accessed when sending email outside outlook (i.e. word or send to mail from Using Outlook 7
W Macro to add a word in Subject Line Using Outlook 1
O Copy email content and paste into new Word Document using a different font Using Outlook 1
K Import 2013 Outlook Contact Address into Word Using Outlook 36
J "Specific word in body" question Using Outlook 1
D opening Word Document in a business contact? BCM (Business Contact Manager) 3
Z Send mail and contents of body from ms word document Using Outlook 1
O Choosing Sending Email Address from Word Using Outlook 5
C Printing Outlook Form Controls via Word Using Outlook 11
S Highlighter colors limited in Outlook 2007 and Word 2007 Using Outlook 1
L Macro to Open a Specific Word Document - Outlook 2007 Using Outlook 17
O Outlook 2010 does not open MS Word attachments Using Outlook 1
R Using Word/OL 2010 to generate personalized email messages Using Outlook 1
S send email attachment from word, message stripped out Using Outlook 1
M Opening Word Doc's in Adobe Acrobat Pro Using Outlook 9
D Word Wrap Subject Using Outlook 1
C Outlook editing won't select just one word Using Outlook 1
