Macro to create task
Nucshuco
Outlook 2013 64 bit
Hope someone can help. I want to be able to run a macro that creates a new task from a specific account. I have multiple exchange accounts. I tried to make one but it always default to the default Data account.
S Macro to create a new contact, 2 appointments, and a task Using Outlook 1
A Create Macro for hyperlink(email) in message body Outlook VBA and Custom Forms 9
L Macro Create Contact and Save Using Outlook 2
L Macro Create Contact and Save Using Outlook 8
S Macro to create notification emails Using Outlook 1
S Macro to create a new folder with subject line as the folder name Using Outlook 2
P Please Help me Create a Macro ! Using Outlook 2
M How to Create Macro in Visual Basic to add Contacts from Personal Folder Using Outlook 4
R How do I create a macro to put text in certain emails? Outlook VBA and Custom Forms 1
D Create a macro in Outlook to run a rule Outlook VBA and Custom Forms 32
N How Can I create an Outlook Macro to import calendar? Outlook VBA and Custom Forms 1
P How do I create a macro to add contacts from email messages? Outlook VBA and Custom Forms 1
J Macro to create folder in PST file Outlook VBA and Custom Forms 4
G Macro: Create New Message and Auto populate To Field Outlook VBA and Custom Forms 5
S How to create a macro to insert a signature in Outlook 2007 Outlook VBA and Custom Forms 1
