Macro Create Contact and Save
LMS
The following code creates a new contact from my form but it will not save and the error is that the parameter value is not valid....what can we do to fix this please?
Sub OpenMyContact()
Dim oContact As outlook.contactItem
Dim oFolder As outlook.MAPIFolder
Set oFolder = Application.Session.GetDefaultFolder(olFolderContacts)
Set oContact = oFolder.Items.Add("IPM.Contact.Contact Form 1.")
oContact.Display
I'm guessing the problem is not with the macro but with the form, probably with one of the custom fields, specifically one of the values in the fields. you'll need ot figure out which field is the problem - look on the All Fields page and check the user defined fields.
How does looking a the All Fields page and check the user defined fields show what there is a problem?
Look at the fields that have values. Does anything look amiss? Are other fields reading values from other fields? Are any of the fields without values set to require a value? (It's not the right error message for that though.)
You'll probably need to open the form in the forms designer and check the properties of each custom field - one option is to delete fields that have values, one at a time, and use run this form and try to save it to identify the field that has a bad parameter. As long you do don't publish the form, you won't lose the fields you delete.
The following code words fine, no problems and it runs another I created named "PastetoFullName" so when I create the contact, it adds to the Full Name of the contact name I copied from somewhere else....and it put's it in a folder as you see...but, is there away that it creates the contact to a folder I select, not the folder name I put in? This way, I don't have to move contacts all the time etc.
Sub NewContactFromNameSelected()
Set oFolder = Application.Session.GetDefaultFolder(olFolderContacts).Folders("New Contacts")
Set oContact = oFolder.Items.Add("IPM.Contact.Contact Form 1")
oContact.Display
Call PastetoFullName
I looked at some other codes re folders and I changed the foregoing to the following, and it creates the contact using my form to the selected folder:
Set oContact = Application.ActiveExplorer.CurrentFolder.Items.Add("IPM.Contact.Contact Form 1")
oContact.Display
There may be other areas again to do things faster, but given how you gave me a form of a code where when I run it, it adds to the fields of the contact a create, I can call that macro at the end of the code I showed, so it will add to the fields immediately when I create the contact....so also I don't know to mark the last answer as a marked answer...but I so appreciate all you have shown me over the time!!
L Macro Create Contact and Save Using Outlook 2
S Macro to create a new contact, 2 appointments, and a task Using Outlook 1
A Create Macro for hyperlink(email) in message body Outlook VBA and Custom Forms 9
S Macro to create notification emails Using Outlook 1
N Macro to create task Using Outlook 1
S Macro to create a new folder with subject line as the folder name Using Outlook 2
P Please Help me Create a Macro ! Using Outlook 2
R How do I create a macro to put text in certain emails? Outlook VBA and Custom Forms 1
D Create a macro in Outlook to run a rule Outlook VBA and Custom Forms 32
N How Can I create an Outlook Macro to import calendar? Outlook VBA and Custom Forms 1
P How do I create a macro to add contacts from email messages? Outlook VBA and Custom Forms 1
J Macro to create folder in PST file Outlook VBA and Custom Forms 4
G Macro: Create New Message and Auto populate To Field Outlook VBA and Custom Forms 5
S How to create a macro to insert a signature in Outlook 2007 Outlook VBA and Custom Forms 1
