Outlook 2019 Macro not working
murgatroyd
Outlook 2019 64-bit
1. I created the following simple macro in Word, to remove space before and after paragraphs in a document.
Sub ClearParagraphSpacing()
Selection.WholeStory
With Selection.ParagraphFormat
.SpaceBefore = 0
.SpaceBeforeAuto = False
.SpaceAfter = 0
.SpaceAfterAuto = False
This works fine in Word, but when I copy it into Outlook, I get an error when I run it on a new email or a reply: "Object variable or With block variable not set." How can I fix this?
2. I can add a shortcut for the macro on the Ribbon or the Quick Access Toolbar, but when I click on it, nothing happens. However, as the macro needs to work in a message editing window (not in the main folder window), does it need a different kind of shortcut?
P Categorise emails on sending - macro not working in Preview mode Using Outlook 1
Matt Johnson Save File Macro Working Sporadically Using Outlook 9
Witzker Outlook 2019 Macro GoTo user defined search folder Outlook VBA and Custom Forms 7
Geldner Send / Receive a particular group via macro or single keypress Using Outlook 1
Witzker HowTo start a macro with an Button in OL contact form Outlook VBA and Custom Forms 12
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
