Customize CreateItemFromTemplate Macro
Hello there!
I am very new to VBA. I created a simple Macro that pulls up a template in Outlook, but I would like to change the address in the 'From' Field. Below is my code so far:
Sub Proposal()
Set msg = Application.CreateItemFromTemplate("C:\Users\My Name \AppData\Roaming\Microsoft\Templates\proposal.oft")
msg.Display
I know that the line I am looking for is:
.SentOnBehalfOfName = "email address"
but I don't understand what I'm doing enough to do anything further. Please advise!
Mike
Thanks Diane! That's actually what I did AFTER the msg.display, but it apparently only works if you put it before.
So appreciative of your help :)
S Outlook 2021 How to customize colors Outlook 2021 & Office 2021 on PC Using Outlook 1
e_a_g_l_e_p_i Trying to customize the ribbon but can't figure this one out Using Outlook 3
S Outlook 2016 Understand and customize prepended behavior of recurring task Using Outlook 0
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
A Customize meeting form. Private notices Outlook VBA and Custom Forms 3
J Customize Attachement Security Warning Using Outlook 1
M Customize Comments / Notes Section time stamp on Contact Records BCM (Business Contact Manager) 0
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT Using Outlook 0
Ankit Agrawal Customize themes in outlook 2010 Using Outlook 1
M please customize this code Using Outlook 1
G Customize Outlook Today folder Using Outlook 0
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
T Customize button image for separate Outlook forms region Outlook VBA and Custom Forms 2
R How to implement customize toolbar in outlook? Outlook VBA and Custom Forms 1
N How to add fields to customize reports in BCM? BCM (Business Contact Manager) 3
C CreateItemFromTemplate throws OutOfMemoryException Outlook VBA and Custom Forms 0
D Request help with a macro for forwarding email Outlook VBA and Custom Forms 5
