How to implement customize toolbar in outlook?
  • Thread starter Thread starter ryotyankou
ryotyankou
I write a addin for outlook, and i create a toolbar for mail editor, as known
that toolbar have a button and when click on it, it will show Add or Remove
buttons, then you can customize the buttons, drag and drop them wherever you
like. how could i do it for my toolbar, here my toolbar is disable that i
can't customize it?
Custom toolbars you create from code don't allow customization from the
Outlook customize dialog.
"ryotyankou " <u48591@uwe> wrote in message
news:98a9b3beeed85@uwe...
> known
> Remove
> you
> can't customize it?
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
S Outlook 2021 How to customize colors Outlook 2021 & Office 2021 on PC Using Outlook 1
e_a_g_l_e_p_i Trying to customize the ribbon but can't figure this one out Using Outlook 3
S Outlook 2016 Understand and customize prepended behavior of recurring task Using Outlook 0
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
A Customize meeting form. Private notices Outlook VBA and Custom Forms 3
J Customize Attachement Security Warning Using Outlook 1
M Customize Comments / Notes Section time stamp on Contact Records BCM (Business Contact Manager) 0
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT Using Outlook 0
M Customize CreateItemFromTemplate Macro Outlook VBA and Custom Forms 2
Ankit Agrawal Customize themes in outlook 2010 Using Outlook 1
M please customize this code Using Outlook 1
G Customize Outlook Today folder Using Outlook 0
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
T Customize button image for separate Outlook forms region Outlook VBA and Custom Forms 2
N How to add fields to customize reports in BCM? BCM (Business Contact Manager) 3
A Quick Access Toolbar Not Showing Description Using Outlook 0
J Text icon in Quick Access toolbar ? Using Outlook 2
O Outlook 365 - Toolbar - Close all items - missing? Using Outlook 3
O Windows 1803 update : QAT and toolbar changed, language pack gone... Using Outlook 5
Diane Poremsky Synchronize Quick Access Toolbar and Ribbons? Using Outlook 0
J Adding Reply & Delete to main toolbar? Using Outlook 0
L Outlook 2007 Custom Form and Toolbar Not Working Using Outlook 5
B Outlook 2007 Save Current View,Font,Toolbar Settings Using Outlook 6
L Outlook 2007 Toolbar Export and Import Using Outlook 7
V Avast! Antispam toolbar Using Outlook 11
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
N Combobox in outlook add ons toolbar not firing event on main window resized Using Outlook 3
B Outlook Toolbar disabled Using Outlook 1
P Can't add a custom hyperlink to toolbar in OL 2010 Using Outlook 1
D How can I add a user created template to the toolbar Outlook VBA and Custom Forms 1
