Customized Sensitivity Levels
  • Thread starter Thread starter Troy
Troy
My manager would like to know if/how can we customize at the server level the
message sensitivity levels (Normal, Personal, Private, or Confidential) in
Outlook 2003/Exchange 2003 to match our corporate categories.
Can you help?
Thanks in advance.
Troy
You can create a custom field for that but the built-in field cannot be
customized.
"Troy" <Troy> wrote in message
news:12D4DE38-D804-41D1-85F1-6D33667921FE@microsoft.com...
> the
> Can you help?
> Thanks in advance.
> Troy
Hi Ken, Can you please share with us how that is done. IU am trying to find
the default apppointment form but can't.
Thank,
Doris
> customized.
> > the
> > Can you help?
> > Thanks in advance.
> > Troy
It's nothing special and it wouldn't replace or supplement the standard
property or values. You just would create a custom form with a property for
your custom values and add a control for it. See the forms information at
www.outlookcode.com for information on custom forms. But again, this just
would be an arbitrary custom field, not a replacement for sensitivity.
"Nagua" <Nagua> wrote in message
news:8B3641C3-C8C2-41E6-8F8E-1FC5E82B0B12@microsoft.com...
> find
> Thank,
> Doris
G Error - "Customized functionality in this application will not work because the certificate" Outlook VBA and Custom Forms 1
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
Witzker Customized Ribbon lost every now and then Using Outlook 3
Witzker Customized ribbon and entries disappeared Using Outlook 0
D Customized Contact Form Losing UDFs. Outlook VBA and Custom Forms 12
G Flag for Follow Up with a customized duetime Using Outlook 1
E Apply customized Business Card for all users Outlook VBA and Custom Forms 0
mikolajek Add on for customized flag operations? Using Outlook 4
B Mass customized emails sent weekly Using Outlook 0
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
S Outlook 2013 - Customized auto-reply message Using Outlook 10
H Date options on Customized Contact form Using Outlook 2
A POST customized as a form Using Outlook 2
G Customized field data problem BCM (Business Contact Manager) 4
B Opening a saved Outlook customized form the same folder Using Outlook 2
B Opening a saved Outlook customized form after moving it to another folder Using Outlook 2
B How to create the customized Outlook SQL DASL for selected days? Outlook VBA and Custom Forms 2
E phone numbers & addresses header disappear (customized contact) Outlook VBA and Custom Forms 7
B Customized Send button Outlook VBA and Custom Forms 5
S Display SharePoint document library in a customized Outlook form Outlook VBA and Custom Forms 1
U Customized Command Button Outlook VBA and Custom Forms 3
H Sensitivity Label Using Outlook 1
U using VBA to set message sensitivity Outlook VBA and Custom Forms 1
M EMail viewing security levels BCM (Business Contact Manager) 1
