Customized Ribbon lost every now and then
Witzker
OS Version(s)
  1. iOS
Outlook 2019 32-bit
Exchange Server 2007
I'm on Outlook 2019
I'm loosing my customized Ribbons in contact and inbox view and also the customized Ribbon and my contact form is replaced by standard ribbon once a day.
Furthermore, I have to import my settings, but after a while it is changed to standard again.
Is This a known issue?
Any idea how to solve this?
THX
I lost my ribbon - discovered it went from the main Outlook (explorer) window to the forms ribbon. I recreated it and its fine, except the simplified ribbon is a separate customization, so I lose them if I switch to simplified. (I have outlook on a big monitor, so I don't need to use the simplified ribbon.)
Try turning off cloud sync - although I don't think it will help with the ribbon, it may help if you are losing other settings.
Go to File > Options > General.
In the Cloud Storage Options, remove the check from "Store my Outlook settings in the cloud"
I have more information in this article - Outlook is not saving preferences
I just noticed that also the customized quick start toolbar is lost
Where are these settings stored?
How can I back up my ribbons on contact, inbox, contact view etc. & quick start toolbar
Are these all stored in one file when I export them?
Witzker Customized ribbon and entries disappeared Using Outlook 0
G Error - "Customized functionality in this application will not work because the certificate" Outlook VBA and Custom Forms 1
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
D Customized Contact Form Losing UDFs. Outlook VBA and Custom Forms 12
G Flag for Follow Up with a customized duetime Using Outlook 1
E Apply customized Business Card for all users Outlook VBA and Custom Forms 0
mikolajek Add on for customized flag operations? Using Outlook 4
B Mass customized emails sent weekly Using Outlook 0
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
S Outlook 2013 - Customized auto-reply message Using Outlook 10
H Date options on Customized Contact form Using Outlook 2
A POST customized as a form Using Outlook 2
G Customized field data problem BCM (Business Contact Manager) 4
B Opening a saved Outlook customized form the same folder Using Outlook 2
B Opening a saved Outlook customized form after moving it to another folder Using Outlook 2
B How to create the customized Outlook SQL DASL for selected days? Outlook VBA and Custom Forms 2
E phone numbers & addresses header disappear (customized contact) Outlook VBA and Custom Forms 7
B Customized Send button Outlook VBA and Custom Forms 5
S Display SharePoint document library in a customized Outlook form Outlook VBA and Custom Forms 1
T Customized Sensitivity Levels Outlook VBA and Custom Forms 3
U Customized Command Button Outlook VBA and Custom Forms 3
R Outlook ribbon menu default? Using Outlook 7
L Getting Index from dropdown inserted on ribbon Outlook VBA and Custom Forms 3
e_a_g_l_e_p_i Trying to customize the ribbon but can't figure this one out Using Outlook 3
W Ribbon XML customization Using Outlook 4
M Simplified ribbon missing Using Outlook 3
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
I Retention policies on outlook 2016 ribbon Using Outlook 2
Wayne Dardis Calling Ribbon Button in Outlook 2016 Outlook VBA and Custom Forms 6
W Adding A Macro To Message Ribbon Outlook VBA and Custom Forms 2
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT Using Outlook 0
M No Show Group on ribbon Using Outlook 8
I Ribbon buttons grayed-out in Outlook 2013 Using Outlook 2
B How can I adjust the ribbon width? I want to see all of my Quick Steps. Using Outlook 1
piusg 2013: Place custom view on the ribbon Using Outlook 3
P Outlook 2007 Calendar Ribbon has changed and I can't fix it Using Outlook 10
R Can I create custom subgroups on the ribbon? Using Outlook 5
M missing iCloud tab on ribbon bar Using Outlook 0
G Adding 3rd-Party Add-In to Home Ribbon in Outlook 2010 Using Outlook 1
E Outlook Ribbon Customization and Deployment Using Outlook 1
C Outlook Calendar Ribbon with iCloud Using Outlook 2
S ADD-IN Ribbon Missing Using Outlook 2
