mailitem Send issue
amh
I have a custom addin that runs code when the mailitem.send event is
fired, however in certain cases the mailitem.send is not fired and it
skips to the application.itemsend event and i don't know why.
Here's the scenario. Compose a new email click "send", mailitem.send
event is fired but due to custom code it appropriately cancels the
event. I then click "send" again, the mailitem.send event is skipped
and the application.itemsend event fires. I don't want to have any
custom code behind the application.item send. I can run the same
scenario on different machines and only find the problem with one
configuration but I can't figure out what it could be. This problems
occurs on specific Windows XP/Outlook 2003 machines.
Any help would be apprecatied.
amh
K
Ken Slovak - [MVP - Outlook]
It sounds to me like you're releasing something after that first Send()
event so your event handler is going out of scope or being garbage
collected. Check for that in your code.
"amh" <amh.4e34546@outlookbanter.com> wrote in message
news:amh.4e34546@outlookbanter.com...
> > amh
amh
Ken,
If it was code I should have the same problem across all the machines.
Again it's just specific to one XP/Outlook 2003 machine. If I create a
new email, enter "abc" in the to: field then click send, the outlook
send event runs first before our custom code and notifies me I have an
invalid recipient, I fix it and then click send again and my custom
code never fires. So it seems whether it's Outlook canceling the send
or our custom code canceling the send, the next time the send button is
clicked our code is never called again. Let me know if you have any
additional insight. Just to reiterate it's specific to a machine. I
have 5 machines running xp/Outlook 2003 and 5 running vista/Outlook
2007 and the issue only occurs on one of the xp machines.
' - [MVP - Outlook Wrote:
> ;321285']It sounds to me like you're releasing something after that
> first Send()
> "amh" amh.4e34546@outlookbanter.com wrote in message
> news:amh.4e34546@outlookbanter.com...-
> > amh -
amh
K
Does the addin code run at all after that on that machine, or is the addin
getting disabled by an unhandled exception? If you open another item and
send it does the code fire? If not that would indicate an unhandled
exception as in my first question or something going out of scope. Other
than some rogue software on that machine that's all I can think of.
"amh" <amh.4f565df@outlookbanter.com> wrote in message
news:amh.4f565df@outlookbanter.com...
> Ken,
amh
Yes the addin still runs. I can open another email or several emails at
one time and the addin still runs. It's quite strange so I was hoping
someone had come across this issue before.
> ;323318']Does the addin code run at all after that on that machine, or
> is the addin
> and
> Other
> "amh" amh.4f565df@outlookbanter.com wrote in message
> news:amh.4f565df@outlookbanter.com...-
> Ken,
> machines.
> a
> an
> is
> 2007 and the issue only occurs on one of the xp machines.-
amh
K
All I can say is if this is on just one machine that the only way to
ultimately figure it out will be to compare the differences on that machine
and try to eliminate them one by one until you narrow it down.
"amh" <amh.4f60ea0@outlookbanter.com> wrote in message
news:amh.4f60ea0@outlookbanter.com...
J Outlook 2007 crashed when pushing send on a displayed mailitem Outlook VBA and Custom Forms 1
N Memory with MailItem.Send Outlook VBA and Custom Forms 1
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
oliv- How to select an mailitem in explorer with "show as conversation" Outlook VBA and Custom Forms 8
JorgeDario How to capture and save the text, when responding a MailItem? Outlook VBA and Custom Forms 3
JorgeDario how to check a MailItem has a digital signature (SMIME) with vba? Outlook VBA and Custom Forms 1
JorgeDario ¿What property of mailitem can be used like primary key? Outlook VBA and Custom Forms 6
C MailItem Find method doesn't work Using Outlook 0
C MailItem.SaveAs not working Outlook VBA and Custom Forms 10
G RE:The signature is also inserted if you touch the MailItem. Outlook VBA and Custom Forms 1
B Add signature to MailItem Outlook VBA and Custom Forms 3
C How can I create a new MailItem inside a user folder? Outlook VBA and Custom Forms 4
S Create a new Outlook MailItem in an Outlook folder(not a draft) Outlook VBA and Custom Forms 2
A How to get OOM MailItem Raw data Outlook VBA and Custom Forms 2
S Saved Property of MailItem is copied Outlook VBA and Custom Forms 1
S MailItem Find Method question Outlook VBA and Custom Forms 6
N Getting the attachments in MailItem Outlook VBA and Custom Forms 1
S ->[O2007] Parsing each line of a MailItem HTMLBody? Outlook VBA and Custom Forms 2
T How to get Inspector or MailItem from wordEditor Outlook VBA and Custom Forms 6
A Select the position of an attached file in a HTML mailitem Outlook VBA and Custom Forms 1
M MailItem object has no property for when a reply was sent Outlook VBA and Custom Forms 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
E Properties added to MailItem in ItemSend event visible to recipien Outlook VBA and Custom Forms 1
V Setting HTMLBody of new mailItem Outlook VBA and Custom Forms 1
V How to find mailitem in the inspector is a brand new one Outlook VBA and Custom Forms 2
M Activate "Add digital signature to this massage" on a MailItem? Outlook VBA and Custom Forms 1
K importing EML in MailItem Outlook VBA and Custom Forms 1
M Get email address from MailItem.To? Outlook VBA and Custom Forms 6
S UserProperties of MailItem object. Outlook VBA and Custom Forms 3
R How to capture a Mailitem Event Outlook VBA and Custom Forms 3
S get current position in message body of mailitem Outlook VBA and Custom Forms 8
S How to get RFC822 format message from the MailItem object. Outlook VBA and Custom Forms 4
D MailItem from an RSS feed Outlook VBA and Custom Forms 2
P Adding a button in a mailitem Outlook VBA and Custom Forms 1
D Max. length of MSO MailItem.EntryID Outlook VBA and Custom Forms 6
R MailItem.Display() error Outlook VBA and Custom Forms 1
R Clone mailitem Outlook VBA and Custom Forms 5
R MailItem Outlook VBA and Custom Forms 2
D Length of the MailItem.EntryID Outlook VBA and Custom Forms 2
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 1
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 5
