How to get OOM MailItem Raw data
  • Thread starter Adriano \(ufficio\)
  • Start date
Adriano \(ufficio\)
this is my need:
I'de like to get an OOM MailItem raw data (RFC 822) using the HrGetOneProp
(from VB6) or similar:
is it possible ?
K
Ken Slovak - [MVP - Outlook]
Do you mean the Internet headers? Yes, it's possible. You would use
HrGetOneProp with the following property tag:
const PR_TRANSPORT_MESSAGE_HEADERS = &H7D001E
How you use HrGetOneProp with VB6 is another story.
"Adriano (ufficio)" <adriano@pippo.it> wrote in message
news:%23HqKbFEvKHA.3536@TK2MSFTNGP06.phx.gbl...
> Hi,
> this is my need:
> is it possible ?
> Thanks
Dmitry Streblechenko
See my reply in the mapi newsgroup.
Please do not multipost.
Dmitry Streblechenko (MVP)
> Hi,
> this is my need:
> is it possible ?
> Thanks
M RDO: using TypeOf to determine [OOM] Class Outlook VBA and Custom Forms 1
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
oliv- How to select an mailitem in explorer with "show as conversation" Outlook VBA and Custom Forms 8
JorgeDario How to capture and save the text, when responding a MailItem? Outlook VBA and Custom Forms 3
JorgeDario how to check a MailItem has a digital signature (SMIME) with vba? Outlook VBA and Custom Forms 1
JorgeDario ¿What property of mailitem can be used like primary key? Outlook VBA and Custom Forms 6
C MailItem Find method doesn't work Using Outlook 0
C MailItem.SaveAs not working Outlook VBA and Custom Forms 10
G RE:The signature is also inserted if you touch the MailItem. Outlook VBA and Custom Forms 1
B Add signature to MailItem Outlook VBA and Custom Forms 3
C How can I create a new MailItem inside a user folder? Outlook VBA and Custom Forms 4
S Create a new Outlook MailItem in an Outlook folder(not a draft) Outlook VBA and Custom Forms 2
S Saved Property of MailItem is copied Outlook VBA and Custom Forms 1
S MailItem Find Method question Outlook VBA and Custom Forms 6
N Getting the attachments in MailItem Outlook VBA and Custom Forms 1
S ->[O2007] Parsing each line of a MailItem HTMLBody? Outlook VBA and Custom Forms 2
T How to get Inspector or MailItem from wordEditor Outlook VBA and Custom Forms 6
A Select the position of an attached file in a HTML mailitem Outlook VBA and Custom Forms 1
M MailItem object has no property for when a reply was sent Outlook VBA and Custom Forms 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
E Properties added to MailItem in ItemSend event visible to recipien Outlook VBA and Custom Forms 1
V Setting HTMLBody of new mailItem Outlook VBA and Custom Forms 1
V How to find mailitem in the inspector is a brand new one Outlook VBA and Custom Forms 2
M Activate "Add digital signature to this massage" on a MailItem? Outlook VBA and Custom Forms 1
K importing EML in MailItem Outlook VBA and Custom Forms 1
A mailitem Send issue Outlook VBA and Custom Forms 5
M Get email address from MailItem.To? Outlook VBA and Custom Forms 6
S UserProperties of MailItem object. Outlook VBA and Custom Forms 3
R How to capture a Mailitem Event Outlook VBA and Custom Forms 3
S get current position in message body of mailitem Outlook VBA and Custom Forms 8
S How to get RFC822 format message from the MailItem object. Outlook VBA and Custom Forms 4
D MailItem from an RSS feed Outlook VBA and Custom Forms 2
J Outlook 2007 crashed when pushing send on a displayed mailitem Outlook VBA and Custom Forms 1
N Memory with MailItem.Send Outlook VBA and Custom Forms 1
P Adding a button in a mailitem Outlook VBA and Custom Forms 1
D Max. length of MSO MailItem.EntryID Outlook VBA and Custom Forms 6
R MailItem.Display() error Outlook VBA and Custom Forms 1
R Clone mailitem Outlook VBA and Custom Forms 5
R MailItem Outlook VBA and Custom Forms 2
D Length of the MailItem.EntryID Outlook VBA and Custom Forms 2
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 1
