MailItem Find Method question
Salad
Using the Find method to find a Subject, I have a couple of questions.
If the Subject is "Test", the following code finds the email. If the
subject is "Re: Test", it does not. I have to remove the prefix. Why
is that?
If the subject is null, my code doesn't find the email. I figure
someone can send an email without a subject. Any idea on correcting it?
If Not IsNull(strSubject) Then
Set objMail = _
objNS.GetDefaultFolder(6).Items.Find("[Subject] = """ & _
strSubject & """")
Set objMail = _
objNS.GetDefaultFolder(6).Items.Find("[Subject] Is Null")
I have a question on finding the email by date as well. I pass a date
field to the function. It converts the date time to a string then
searches. Out of 10 email times passed to it, if found only 1. Any
idea whay the code below fails the majority of the time?
strTime = Format(datTime, "m/d/yyyy h:nn AMPM")
Set objMail = objNS.GetDefaultFolder(6).Items.Find("[ReceivedTime]= """
& strTime & """")
Michael Bauer
If strSubject is declared as a String type, it never will be Null. Instead
use IsEmpty, or even better just:
If str="" then...
Actually you'd need the LIKE operator in the filter, but that's not
supported. So you'd have to loop through all the collection, and check each
item with
If item.subject like "*whatever*" Then ...
More flexible, and a lot faster, are the Restriction* objects from the
Redemption (www.dimastr.com)
Best regards
Michael Bauer
Am Sun, 21 Feb 2010 15:28:08 -0800 schrieb Salad:
> is that?
> Set objMail = _
> strSubject & """")
> Else
> Set objMail = _
> End If
> & strTime & """")
Dmitry Streblechenko
Under the hood, Outlook searches on the PR_NORMALIZED_SUBJECT (which does
not include the prefix), not PR_SUBJECT.
Where does the strSubject come from? Do you actually store it? Or does the
user type it?
Dmitry Streblechenko (MVP)
"Salad" <salad@oilandvinegar.com> wrote in message
news:LO2dnaTQZ-MYXBzWnZ2dnUVZ_u2dnZ2d@earthlink.com...
> Using the Find method to find a Subject, I have a couple of questions. If
> the Subject is "Test", the following code finds the email. If the subject
> is "Re: Test", it does not. I have to remove the prefix. Why is that?
> If the subject is null, my code doesn't find the email. I figure someone
> Set objMail = _
> strSubject & """")
> Else
> Set objMail = _
> End If
> searches. Out of 10 email times passed to it, if found only 1. Any idea
> Set objMail = objNS.GetDefaultFolder(6).Items.Find("[ReceivedTime]= """ &
> strTime & """")
Salad
> user type it?
In Access, one can do a File/Import/GetExternalData and link an inbox,
sent, etc folder and it's now a table, similar to an Excel spreadsheet.
So I'm using info from the inbox in my testing.
One of the fields is "Subject" that contains the entire subject line
"Re: Test". Another field is "Subject Prefix" with just the "Re:", and
"Normalized Subject" that contains "Test"
Besides the subject fields , there's also the
received/created/lastmodified columns, the email size, sender name, and
a few other fields like the body.
I thought it'd be relatively simple to find the email.
Works like a champ on the normalized subject as you noted.
I can'r find the email if the subject line is null.
I can't find the email based on any datetime stamp.
Works like a champ on message size.
But I figure there can be one or more emails with the same subject line,
same message size, or same datetimestamp. But all three? I don't think so.
Since the .Find method works fine on the subject and size fields, I'm
obviously passing the wrong filter for a null (blank) subject and for
the date.
I've tried, and failed on
> Find("IsEmpty([Subject]")
> Find("IsNull([Subject]")
> Find("[Subject] = ''")
and for dates
'Set objMail = .Find("[ReceivedTime]= '1/1/2010 3:34:00 AM'")
and Jan 1, 2010, January 1,2010, no seconds, no AM, just the date,
nothing works. Single quotes, double quotes, it doesn't seem to matter.
Based on the above, do you spot anything obvious that is in error? Or
other tests I could make? Or a link to compare my code to for finding
an email?
Searching by subject is a bad idea, to put it mildly :) What happens if you
have multiple messsages with the same subject?
Use the EntryID property and open the item using using
Application.Session.GetItemFromID. There is no reason to search.
news:sZCdnUnqUfV6Wh_WnZ2dnUVZ_omdnZ2d@earthlink.com...
> > does not include the prefix), not PR_SUBJECT.
> > the user type it?
> sent, etc folder and it's now a table, similar to an Excel spreadsheet. So
> One of the fields is "Subject" that contains the entire subject line "Re:
> received/created/lastmodified columns, the email size, sender name, and a
> so.
> obviously passing the wrong filter for a null (blank) subject and for the
> date.
> .Find("IsEmpty([Subject]")
> .Find("IsNull([Subject]")
> .Find("[Subject] = ''")
> and for dates
> and Jan 1, 2010, January 1,2010, no seconds, no AM, just the date, nothing
> other tests I could make? Or a link to compare my code to for finding an
> email?
Salad
Wouldn't you know, EntryID is not one of the columns in the table tha is
created in Access if one links a folder.
Well, MS gave us/me the partial information, but not all unfortunately.
The table lets one know if there are attachments or not, but not the
attachment names nor as it appears an easy way to find the email. Thus
I'd need a way to find the email if it had attachments.
If you cannot get entry id as one of the columns, don't use
File/Import/GetExternalData.
news:0LKdnbICRb0Emx7WnZ2dnUVZ_qednZ2d@earthlink.com...
> > you have multiple messsages with the same subject?
C MailItem Find method doesn't work Using Outlook 0
V How to find mailitem in the inspector is a brand new one Outlook VBA and Custom Forms 2
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
oliv- How to select an mailitem in explorer with "show as conversation" Outlook VBA and Custom Forms 8
JorgeDario How to capture and save the text, when responding a MailItem? Outlook VBA and Custom Forms 3
JorgeDario how to check a MailItem has a digital signature (SMIME) with vba? Outlook VBA and Custom Forms 1
JorgeDario ¿What property of mailitem can be used like primary key? Outlook VBA and Custom Forms 6
C MailItem.SaveAs not working Outlook VBA and Custom Forms 10
G RE:The signature is also inserted if you touch the MailItem. Outlook VBA and Custom Forms 1
B Add signature to MailItem Outlook VBA and Custom Forms 3
C How can I create a new MailItem inside a user folder? Outlook VBA and Custom Forms 4
S Create a new Outlook MailItem in an Outlook folder(not a draft) Outlook VBA and Custom Forms 2
A How to get OOM MailItem Raw data Outlook VBA and Custom Forms 2
S Saved Property of MailItem is copied Outlook VBA and Custom Forms 1
N Getting the attachments in MailItem Outlook VBA and Custom Forms 1
S ->[O2007] Parsing each line of a MailItem HTMLBody? Outlook VBA and Custom Forms 2
T How to get Inspector or MailItem from wordEditor Outlook VBA and Custom Forms 6
A Select the position of an attached file in a HTML mailitem Outlook VBA and Custom Forms 1
M MailItem object has no property for when a reply was sent Outlook VBA and Custom Forms 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
E Properties added to MailItem in ItemSend event visible to recipien Outlook VBA and Custom Forms 1
V Setting HTMLBody of new mailItem Outlook VBA and Custom Forms 1
M Activate "Add digital signature to this massage" on a MailItem? Outlook VBA and Custom Forms 1
K importing EML in MailItem Outlook VBA and Custom Forms 1
A mailitem Send issue Outlook VBA and Custom Forms 5
M Get email address from MailItem.To? Outlook VBA and Custom Forms 6
S UserProperties of MailItem object. Outlook VBA and Custom Forms 3
R How to capture a Mailitem Event Outlook VBA and Custom Forms 3
S get current position in message body of mailitem Outlook VBA and Custom Forms 8
S How to get RFC822 format message from the MailItem object. Outlook VBA and Custom Forms 4
D MailItem from an RSS feed Outlook VBA and Custom Forms 2
J Outlook 2007 crashed when pushing send on a displayed mailitem Outlook VBA and Custom Forms 1
N Memory with MailItem.Send Outlook VBA and Custom Forms 1
P Adding a button in a mailitem Outlook VBA and Custom Forms 1
D Max. length of MSO MailItem.EntryID Outlook VBA and Custom Forms 6
R MailItem.Display() error Outlook VBA and Custom Forms 1
R Clone mailitem Outlook VBA and Custom Forms 5
R MailItem Outlook VBA and Custom Forms 2
D Length of the MailItem.EntryID Outlook VBA and Custom Forms 2
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 1
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 5
