How to get MailItem.Body without security warning in Outlook 2010
Tom
Now I run the following code in Outlook 2010, it shows security warning
dialog. My question is that how to go without the dialog.
MailItem oMailItem
' here it is true that oMailItem is valid object
str = oMailItem.Body ' this line cause security warning
The test is
"A program is trying to acces e-mail address information stored in Outlook.
If this is unexpected, click Deny and verity your antivirus software is
up-to-data.
For more information about e-mail safety and how you might be able to avoid
getting this warning, click help."
Next is a check box for "Allow access for" right is a dropdown combobox "1
minute"
The last is 3 buttons as "Allow", "Deny" and "Help", in which "Deny" is
default one.
For what I know now is that when calling oMailItem.Body, Outlook will
extract string text from RTF format stored internally (but I am not sure if
it is so in Outlook 2010). And both Body & HTMLBody are protected now. Any
access to them will prompt warning dialog unless anti-virus program is
up-to-date. Unfortunately our program will assume to running in user's
machine with/without anti-virus applications.
I also try to use MAPI library with C++ code. It has no security warning
dialog when I get the email text like code:
IMessage* pMsg;
IStream* pStream;
STATSTG stg = {0};
// here pMsg & pStream are valid pointers
pMsg->OpenProperty(PR_BODY, &IID_IStream, STGM_READWRITE, 0,
(IUnknown**)&istream);
pStream->Stat(*stg, 0);
int bodysize = stg.cbSize.LowPart; // won't bother checking for >2gb messages!
char* bodybuf = new char[bodysize+1];
ULONG red;
HRESULT hr = pStream->Read(bodybuf, bodysize, &red);
// I am able to get email body text without security warning
// however if I try to change email body, return code is "access deny" like
std::string strtest;
strtest = bodybuf;
strtest += " test";
hr = pStream->->Write(strtest, strtest.GetLength(), &red);
Any suggestion?
Thanks in advance.
Tom
Michael Bauer
The important part is missing: how do you get the MailItem? You need to
derive it from the instrinsic Application object, that is not from an
Application variable created by GetObject or CreateObject.
Best regards
Michael Bauer
Am Thu, 14 Jan 2010 10:21:02 -0800 schrieb Tom:
> Hi,
> MailItem oMailItem
> The test is
Outlook.
> up-to-data.
avoid
> minute"
> default one.
if
> IMessage* pMsg;
> IStream* pStream;
> STATSTG stg = {0};
messages!
> ULONG red;
like
> strtest = bodybuf;
> strtest += " test";
> Any suggestion?
> Thanks in advance.
> Tom
Tom
Re: How to get MailItem.Body without security warning in Outlook 2
Hi Michael,
I get the MailItem object as following code sample. The code is written in
C++ with Outlook import.
#import "C:\Program Files\Common Files\microsoft shared\OFFICE14\mso.dll"
#import "C:\Program Files\Microsoft Office\Office14\MSOUTL.OLB"
rename_namespace("Outlook")
void test()
Outlook::_ApplicationPtr spApp("Outlook.Application");
if (NULL == spApp)
hr = spApp.CreateInstance("Outlook.Application");
if (spApp)
// from now on spApp is the valid Outlook.Application object in VBA
Outlook::_ExplorerPtr spExplorer = spApp->ActiveExplorer();
if (spExplorer)
Outlook::SelectionPtr spSel = spEcplorer->GetSelection();
if (spSel && spSel->Count == 1) // if only 1 selection
// assume that the selection is a mail item
Outlook::_MailItemPtr spMailItem = spSel->Item(1);
// the following line will bring up the security warning
dialog
::OutputDebugString(spMailItem.Body);
Other than the security warning dialog and if I click "allow", the output
text is exactly as the content of the email item I selected.
Tom
> > Best regards
> Michael Bauer
> > Hi,
> > MailItem oMailItem
> > The test is
> Outlook.
> > up-to-data.
> avoid
> > minute"
> > default one.
> if
> > IMessage* pMsg;
> > IStream* pStream;
> > STATSTG stg = {0};
> messages!
> > ULONG red;
> like
> > strtest = bodybuf;
> > strtest += " test";
> > Any suggestion?
> > Thanks in advance.
> > Tom
S get current position in message body of mailitem Outlook VBA and Custom Forms 8
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
oliv- How to select an mailitem in explorer with "show as conversation" Outlook VBA and Custom Forms 8
JorgeDario How to capture and save the text, when responding a MailItem? Outlook VBA and Custom Forms 3
JorgeDario how to check a MailItem has a digital signature (SMIME) with vba? Outlook VBA and Custom Forms 1
JorgeDario ¿What property of mailitem can be used like primary key? Outlook VBA and Custom Forms 6
C MailItem Find method doesn't work Using Outlook 0
C MailItem.SaveAs not working Outlook VBA and Custom Forms 10
G RE:The signature is also inserted if you touch the MailItem. Outlook VBA and Custom Forms 1
B Add signature to MailItem Outlook VBA and Custom Forms 3
C How can I create a new MailItem inside a user folder? Outlook VBA and Custom Forms 4
S Create a new Outlook MailItem in an Outlook folder(not a draft) Outlook VBA and Custom Forms 2
A How to get OOM MailItem Raw data Outlook VBA and Custom Forms 2
S Saved Property of MailItem is copied Outlook VBA and Custom Forms 1
S MailItem Find Method question Outlook VBA and Custom Forms 6
N Getting the attachments in MailItem Outlook VBA and Custom Forms 1
S ->[O2007] Parsing each line of a MailItem HTMLBody? Outlook VBA and Custom Forms 2
T How to get Inspector or MailItem from wordEditor Outlook VBA and Custom Forms 6
A Select the position of an attached file in a HTML mailitem Outlook VBA and Custom Forms 1
M MailItem object has no property for when a reply was sent Outlook VBA and Custom Forms 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
E Properties added to MailItem in ItemSend event visible to recipien Outlook VBA and Custom Forms 1
V Setting HTMLBody of new mailItem Outlook VBA and Custom Forms 1
V How to find mailitem in the inspector is a brand new one Outlook VBA and Custom Forms 2
M Activate "Add digital signature to this massage" on a MailItem? Outlook VBA and Custom Forms 1
K importing EML in MailItem Outlook VBA and Custom Forms 1
A mailitem Send issue Outlook VBA and Custom Forms 5
M Get email address from MailItem.To? Outlook VBA and Custom Forms 6
S UserProperties of MailItem object. Outlook VBA and Custom Forms 3
R How to capture a Mailitem Event Outlook VBA and Custom Forms 3
S How to get RFC822 format message from the MailItem object. Outlook VBA and Custom Forms 4
D MailItem from an RSS feed Outlook VBA and Custom Forms 2
J Outlook 2007 crashed when pushing send on a displayed mailitem Outlook VBA and Custom Forms 1
N Memory with MailItem.Send Outlook VBA and Custom Forms 1
P Adding a button in a mailitem Outlook VBA and Custom Forms 1
D Max. length of MSO MailItem.EntryID Outlook VBA and Custom Forms 6
R MailItem.Display() error Outlook VBA and Custom Forms 1
R Clone mailitem Outlook VBA and Custom Forms 5
R MailItem Outlook VBA and Custom Forms 2
D Length of the MailItem.EntryID Outlook VBA and Custom Forms 2
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 1
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 5
