SmallScroll Method
  • Thread starter Thread starter amh
amh
Is there a way to use this method in Outlook? I've tried accessing it
through the activeInspector but I cannot find it. I need to be able to
scroll the contents of the active email.
Any suggestions?
amh
It's not available and I don't know of a way to do what you want.
"amh" <amh.5954d9b@outlookbanter.com> wrote in message
news:amh.5954d9b@outlookbanter.com...
> Any suggestions?
> > amh
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
oliv- FASTEST METHOD TO ENUMERATE FOLDERS Outlook VBA and Custom Forms 3
Diane Poremsky My Speedy CPAO Modification Method Using Outlook 0
N Get the seconds with userproperties.add method VBA Outlook Outlook VBA and Custom Forms 4
S Best method to use Outlook Standalone with iPhone Using Outlook 13
G run-time 438: object doesn't support this property or method Using Outlook 2
A Need method to rapidly correct telephone contact telephone number formatting Using Outlook 1
C MailItem Find method doesn't work Using Outlook 0
S Looking for client-side method (Outlook 2007/Exchange 2007) for users to delete Outlook VBA and Custom Forms 2
S Restrict method question on email. What am I doing wrong? Outlook VBA and Custom Forms 2
S MailItem Find Method question Outlook VBA and Custom Forms 6
D Call add-in method from macro? Outlook VBA and Custom Forms 1
P Question on getExchangeUser method in Outlook Add-in Outlook VBA and Custom Forms 3
P pasteface method crashing outlook Outlook VBA and Custom Forms 7
M Create email from Access on Outlook and make sure that email has beensent using WithEvents method Outlook VBA and Custom Forms 3
