Restrict method question on email. What am I doing wrong?
  • Thread starter Thread starter Salad
Salad
I'm not getting a subroutine to return the correct counts based on using
the Restrict method. Is it because I am passing the wrong date format?
If I pass a comparison: Received >= Date1 And < Date2, I get all recs
greater/equal date1.
If I only want records for Date1, I get 0 records. Received = Date1
If I want all records >=1 date, I get correct count. Received >= Date1
Below I show the call to the subroutine and by routine. Any clue what I
am doing wrong? Thanks for any advice.
RestrictItems _
"00000000F01460E0716E454B8398DD735E95C4CA82800000", _
"2/24/2010", "2/25/2010"
Sub RestrictItems(strEntryID As String, _
strDate1 As String, strDate2 As String)
Dim olApp As Object
Dim olNS As Object
Dim olFolders As Object
Dim olItems As Object
Dim olMailItem As Object
Dim olRestrict As Object
Set olApp = GetObject(, "Outlook.Application")
Set olNS = olApp.GetNamespace("MAPI")
Set olFolders = _
olApp.GetNamespace("Mapi").GetFolderFromID(strEntryID)
Set olItems = olFolders.Items
'1. this line returns all items from both dates. Incorrect
Set olRestrict = olItems.Restrict("[CreationTime] >= """ _
& strDate1 & """ And [ReceivedTime] < """ & strDate2 & """")
'2. this line returns 0. Incorrect
Set olRestrict = olItems.Restrict("[CreationTime] = """ & _
strDate1 & """")
'3. this line returns all items from both dates. Correct
& strDate1 & """")
'used for all 3 options/comparisons
MsgBox "Count is " & olRestrict.Count
You shoud always use a range for date/time properties.
Date = 2/24/2010
makes no sense even if you have a matching item with Date = "2/24/2010
00:00:000", firstly because there is always a roundoff error, and secondly
because I suspect that when you say
Date = 2/24/2010
you really mean
(Date >= "2/24/2010 00:00:000") And (Date < "2/25/2010 00:00:000")
Dmitry Streblechenko (MVP)
"Salad" <salad@oilandvinegar.com> wrote in message
news:5dmdnauvb-C_URvWnZ2dnUVZ_omdnZ2d@earthlink.com...
> RestrictItems _
> Dim olApp As Object
> Dim olNS As Object
> Set olFolders = _
> strDate1 & """")
> & strDate1 & """")
> End Sub
> Date = 2/24/2010
> Date = 2/24/2010
> you really mean
Thanks. Got it working now.
G Outlook Contact Item.Restrict where FullName is NULL Outlook VBA and Custom Forms 3
L Restrict accepted appts to specific calendar Using Outlook 2
oliv- .RESTRICT returning birthdays regardless of the filtering date Outlook VBA and Custom Forms 8
M Using .Restrict with a UserProperty in an Exchange folder Outlook VBA and Custom Forms 4
JorgeDario restrict access to a certain folder with vba Outlook VBA and Custom Forms 3
JorgeDario How to restrict the creation of new folders? Outlook VBA and Custom Forms 2
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
M Restrict throwing 'Condition is not valid' error Outlook VBA and Custom Forms 5
M Restrict Appointments by EntryID not working Outlook VBA and Custom Forms 1
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
oliv- FASTEST METHOD TO ENUMERATE FOLDERS Outlook VBA and Custom Forms 3
Diane Poremsky My Speedy CPAO Modification Method Using Outlook 0
N Get the seconds with userproperties.add method VBA Outlook Outlook VBA and Custom Forms 4
S Best method to use Outlook Standalone with iPhone Using Outlook 13
G run-time 438: object doesn't support this property or method Using Outlook 2
A Need method to rapidly correct telephone contact telephone number formatting Using Outlook 1
C MailItem Find method doesn't work Using Outlook 0
S Looking for client-side method (Outlook 2007/Exchange 2007) for users to delete Outlook VBA and Custom Forms 2
S MailItem Find Method question Outlook VBA and Custom Forms 6
A SmallScroll Method Outlook VBA and Custom Forms 1
D Call add-in method from macro? Outlook VBA and Custom Forms 1
P Question on getExchangeUser method in Outlook Add-in Outlook VBA and Custom Forms 3
P pasteface method crashing outlook Outlook VBA and Custom Forms 7
M Create email from Access on Outlook and make sure that email has beensent using WithEvents method Outlook VBA and Custom Forms 3
S Thank you Diane, Plus pst files question Using Outlook 8
J Outlook inbox question Using Outlook 4
D.Moore Preview pane question Outlook VBA and Custom Forms 3
D.Moore Outlook desktop client suggested searches question Using Outlook 22
e_a_g_l_e_p_i Question about Outlook 2021 and Gmail Using Outlook 8
G Question marks in messages Using Outlook 2
e_a_g_l_e_p_i Question about calendar Using Outlook 5
e_a_g_l_e_p_i Question about installing my Gmail account on my iPhone but still getting messages downloaded to my desktop Outlook. Using Outlook 3
e_a_g_l_e_p_i Question about reinstalling Outlook 2021 Using Outlook 5
e_a_g_l_e_p_i question about 2-Step Verification with my gmail Using Outlook 0
D Question on removing an alias Using Outlook 1
e_a_g_l_e_p_i A few question before I decide to switch to Pop from imap Using Outlook 9
D.Moore SendAndReceive question Outlook VBA and Custom Forms 2
N Question Using Outlook 8
