instr function
Joel Allen
Outlook 2003 SP3
I'm trying to find * and ? in the string. Do I have to do two separate if
statements, or can I use some kind of OR statement? This isn't working:
If Instr(1, Item.UserProperties("JobName"), "*" or "?", vbTextCompare) > 0
Then
MsgBox "Sorry, you cannot use the * or ? character"
end if
Joel
Salad
Joel Allen wrote:
> Outlook 2003 SP3
> Hi,
> Then
> Exit Sub
> end if
> Thanks,
> Joel
x = "Joe Blow"
? (ubound(split(x,"*")) or ubound(split(x,"?"))) > 0 'False
x = "Joe*Blow"
? (ubound(split(x,"*")) or ubound(split(x,"?"))) > 0 'True
x = "Joe Blow?"
x = "Joe*Blow?"
Or you could use Instr() but 2 separate comparisons as well.
L Outlook saved template function too limited Using Outlook 2
R Creating a user defined function Outlook VBA and Custom Forms 3
A How to assign the value returned by the regex execute function to a variable? Using Outlook 1
B Search function in Office 365 has stopped working Using Outlook 3
T Query About "Delay Delivery" Function Using Outlook 5
M Constant indexing/no search function Using Outlook 0
B Search function "to: ONLY Bob" Using Outlook 1
K Outlook 2007 Calendar - Time spinner does not function correctly Using Outlook 1
B The “run a script” function stopped unexpectedly in Outlook2007 Using Outlook 6
R searching a not function Using Outlook 2
E Outlook 2007 backup and restore function Using Outlook 2
R Serach Function Using Outlook 3
S Error from Folder.MoveTo function Outlook VBA and Custom Forms 2
M DASL Filter function? Outlook VBA and Custom Forms 3
M Today(S) function in DASL Filter Outlook VBA and Custom Forms 1
I Today function in Outlook Forms Outlook VBA and Custom Forms 1
J Include calculations in the lookup function Outlook VBA and Custom Forms 1
B Outlook Script ( using calendar function in a form) Outlook VBA and Custom Forms 3
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
A Programmatically duplicating BCM's "Link to Record" function BCM (Business Contact Manager) 2
Z WebView doesnt function with separate pst Outlook VBA and Custom Forms 3
