Serach Function
Rick203
For my job I have a lot of different folders in my Outlook. with a lot of subfolders, this because there are a lot of different clients from different companies. So my Outlook looks like this
- Company
-- Company Division
--- Name
--- Name
--- Name
--- Name
--- etc.
- Company
-- Company Division
--- Name
--- Name
--- etc.
-- Company Division
--- Name
--- Name
--- etc.
Right now I have about 400 folders but I get more everyday.
I tried to use the search function to figure out which person needed to go to which company but when I do a search I only get all the e-mail relating to that person, not the place where it is stored (i.e. Outlook/Inbox/Company/Division/Name)
Is it possible to have this shown? Or is is possible to only search on map names, not on e-mails?
it's not possible (or easily possible) in Outlook 2007. You can use advanced find and a convoluted process to figure it out - or if using windows 7, search using the Start search field. That shows the full path in outlook.
http://www.outlook-tips.net/2011/1226/find-folder-path-in-mailbox/
if you know the folder name, the vba code can help - http://www.vboffice.net/en/developers/find-folder-by-name
Suggestion: Do you really need the individual's in different folder? We recommend let detailed filing - in your case, by company, although by devision also makes sense when the divisions are never in the same conversation. What you want to avoid is having messages in a 3way conversation with Bob and Bill in separate folders. Use Instant search, custom views, or search folders to sort within the main folder.
Yuri m.
I think that if you need to file emails by topic to so many folders you should look at tools that automate this for you. there are several out there.
This way you will not need to rely on the search function to find emails pertaining to a specific topic.
Intelligent email filing with TuckAway by
www.celiosoft.com
Rick203
Re: Search Function
www.celiosoft.com
Right now I'm using the VBA code which is working great thank you so much :)
But being the lazy person I am.... :p If there is a program that automates it for me that might be interesting, what are some examples of programs like this? I wouldn't know where to start looking
L Outlook saved template function too limited Using Outlook 2
R Creating a user defined function Outlook VBA and Custom Forms 3
A How to assign the value returned by the regex execute function to a variable? Using Outlook 1
B Search function in Office 365 has stopped working Using Outlook 3
T Query About "Delay Delivery" Function Using Outlook 5
M Constant indexing/no search function Using Outlook 0
B Search function "to: ONLY Bob" Using Outlook 1
K Outlook 2007 Calendar - Time spinner does not function correctly Using Outlook 1
B The “run a script” function stopped unexpectedly in Outlook2007 Using Outlook 6
R searching a not function Using Outlook 2
E Outlook 2007 backup and restore function Using Outlook 2
S Error from Folder.MoveTo function Outlook VBA and Custom Forms 2
J instr function Outlook VBA and Custom Forms 1
M DASL Filter function? Outlook VBA and Custom Forms 3
M Today(S) function in DASL Filter Outlook VBA and Custom Forms 1
I Today function in Outlook Forms Outlook VBA and Custom Forms 1
J Include calculations in the lookup function Outlook VBA and Custom Forms 1
B Outlook Script ( using calendar function in a form) Outlook VBA and Custom Forms 3
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
A Programmatically duplicating BCM's "Link to Record" function BCM (Business Contact Manager) 2
Z WebView doesnt function with separate pst Outlook VBA and Custom Forms 3
