Today(S) function in DASL Filter
  • Thread starter Thread starter Mark B
Mark B
I am trying to figure out how to use the "undocumented" Today(S) function.
Basically I have about 10 search folders that make use of most of these:
%yesterday
%today
%tomorrow
%last7days
%next7days
%lastweek
%thisweek
%nextweek
%lastmonth
%thismonth
%nextmonth
So I am also hoping that these functions also allow for passing of a (S)
seconds parameter.
The reason I am hoping to do this is to pre-adjust my UTC DateTime field
"MileStone1UTC" so that it will be normalized into local date/time.
e.g.
"http://schemas.microsoft.com/mapi/string/{00020329-0000-0000-C000-000000000046}/MileStone1UTC"
= Today(46800)
e.g.
= Tomorrow(46800)
However it doesn't work. Anyone know what will here?
Here's the article I was referencing:
http://blogs.msdn.com/andrewdelin/archive/2005/08/08/448882.aspx
-Snip -
Outlook SQL DASL syntax - an update
Here's an update to my previous blog entry on Doing more with Outlook filter
and SQL DASL syntax.
I had some great feedback from my previous posting, there is obviously a
need for more information about how to "do stuff" with Outlook filters.
Special thanks to Patrick for a very useful message, which showed me how to
use dynamic dates in Outlook filter queries. Previously I thought this was
impossible! Patrick's trick (:o) is to use the today(S) function with a
parameter in seconds (S). The parameter gives a positive or negative offset
from today and can be used to check the Due Date of tasks (or any other date
test you like).
Here is Patrick's example which he uses on the Tasks folder:
("http://schemas.microsoft.com/mapi/id/{00062003-0000-0000-C000-000000000046}/811c000b"= 0) AND (NOT("http://schemas.microsoft.com/mapi/id/{00062003-0000-0000-C000-000000000046}/81050040" IS NULL)) AND ("http://schemas.microsoft.com/mapi/id/{00062003-0000-0000-C000-000000000046}/81050040" <= today(864000)))When applied to a task folder, this shows 'not completed' tasks that have aDue Date set in the next 10 days from today.This same technique should be useful for filtering on received date (etc) onemail folders and others.-Snip end-
Maybe if I knew what Today(0) equated to I could use that if it was an exact
time such as Saturday, January 30, 12:00 AM.
Then I could use:
MileStone1UTC >= Today(0+46800) AND MileStone1UTC <
Today(0+46800+(24*60*60))
where 46800 is 13 hours in my case -- that is the UTC offset from local
time.
"Mark B" <none123@none.com> wrote in message
news:echK4MWoKHA.5524@TK2MSFTNGP05.phx.gbl...
> %yesterday
> %today
> %tomorrow
> %last7days
> %next7days
> %lastweek
> %thisweek
> %nextweek
> %lastmonth
> %thismonth
> %nextmonth
> seconds parameter.
> e.g.
> = Today(46800)
> e.g.
> = Tomorrow(46800)
> -Snip -
> filter and SQL DASL syntax.
> to use dynamic dates in Outlook filter queries. Previously I thought this
> was impossible! Patrick's trick (:o) is to use the today(S) function with
> a parameter in seconds (S). The parameter gives a positive or negative
> offset from today and can be used to check the Due Date of tasks (or any
> other date test you like).
> 0) AND
> IS NULL)) AND
M Today(S) function in DASL Filter Outlook VBA and Custom Forms 1
I Today function in Outlook Forms Outlook VBA and Custom Forms 1
C Outlook 365 What happened to the "Today" button? Using Outlook 13
Victor_50 Outlook 365 Quick search by period (today, yesterday, last week) completely missing in newest OL 365 Using Outlook 0
R unable to filter tasks when start date is on or before today Using Outlook 4
K Accentuating today in Outlook calendar month view Using Outlook 2
S stop calendar date reverting to today Using Outlook 7
Diane Poremsky Make 'today' stand out more in the calendar Using Outlook 0
T OL 2010 "Outlook Today" Entries Disappear Using Outlook 0
A Show ALL of today's appointments in To-Do Bar Using Outlook 1
F Outlook 2007 Calendar Appointments not in Outlook Today view Using Outlook 11
S Custom view in todo bar with "Today," "tomorrow" groupings Using Outlook 2
A OUTLOOK TODAY SCREEN Using Outlook 1
smokiibear Custom Today Page Using Outlook 1
T Events Not Showing In Outlook Today Using Outlook 3
W Midnight bug - Outlook Today & reminders Using Outlook 5
M Filter today's mail Using Outlook 2
smokiibear How to modify Today Page to Include tasks from other task folders Using Outlook 1
M Outlook Today. How to rename IMAP inbox accounts to something else than inbox? Using Outlook 4
G Customize Outlook Today folder Using Outlook 0
M How can I get new styles for Outlook Today 2003? Using Outlook 1
E Calendar View - Go to Today (Alt+O keystroke gone in 2010) Using Outlook 2
B 2003 >> 2010 outlook today security changes (Iframes? Href?) Using Outlook 1
B link to group schedules from Today screen Using Outlook 2
R Getting my Claendar additions to appear in Outlook Today Using Outlook 7
C Missing "Customise Outlook Today" button Using Outlook 4
H Outlook 2007 - hide completed tasks from Outlook Today -Solution Using Outlook 2
S Outlook 2007 caendar hangs when I select today's day BCM (Business Contact Manager) 4
M How do I get Outlook Today to show appts from multiple calendars? Using Outlook 5
N VBA code to show today's date + a sequencial number in subject lin Outlook VBA and Custom Forms 1
D Get a list of today's events from Outlook Outlook VBA and Custom Forms 2
E FUNCTION SEND/RECEIVE OUTLLOK AND VB6 Outlook VBA and Custom Forms 3
L Outlook saved template function too limited Using Outlook 2
R Creating a user defined function Outlook VBA and Custom Forms 3
A How to assign the value returned by the regex execute function to a variable? Using Outlook 1
B Search function in Office 365 has stopped working Using Outlook 3
T Query About "Delay Delivery" Function Using Outlook 5
M Constant indexing/no search function Using Outlook 0
B Search function "to: ONLY Bob" Using Outlook 1
K Outlook 2007 Calendar - Time spinner does not function correctly Using Outlook 1
