Connecting to an addin in Outlook 2010 (or not)
  • Thread starter Thread starter CyberEeyor
C
CyberEeyor
Well, this is really a VB question, but this discussion group seems to be as
close as I can get. Please redirect me if there is a better place to ask this
question.
I'm trying to set up an Outlook addin using 2010 beta. A skeleton of the
code is shown below.
When I start Outlook, the addin shows up in the list of active addin. I get
the "Mail Checker addin created" and "Mail Checker addin deleted" messages at
the appropriate times. But I never seem to enter any of the IDTExtensibility2
subroutines. Equivalently, Outlook never seems to actually connect to my
addin.
Am I missing some message handler hook-up or something. I haven't seen
anything else in any of the MSDN examples. Are addins in Outlook 2010 beta
fully operational? I will be happy to try any and all suggestions.
CyberEeyor
Imports Outlook = Microsoft.Office.Interop.Outlook
Imports System.Runtime.InteropServices
Imports System.Reflection
Imports Extensibility
Public Class MailCheckerAddin
Implements IDTExtensibility2
Private Sub ThisAddIn_Startup(ByVal sender As Object, _
ByVal e As System.EventArgs) Handles
Me.Startup
MsgBox("Mail Checker addin created")
Private Sub ThisAddIn_Shutdown(ByVal sender As Object, _
Me.Shutdown
MsgBox("Mail Checker addin deleted")
Private Sub IDTExtensibility2_OnAddInsUpdate(ByRef custom As System.Array) _
Implements
IDTExtensibility2.OnAddInsUpdate
MsgBox("Mail Checker notified that add-in have changed.")
Private Sub IDTExtensibility2_OnBeginShutdown(ByRef custom As
System.Array) _
Implements
IDTExtensibility2.OnBeginShutdown
Private Sub IDTExtensibility2_OnConnection(ByVal Application As Object, _
ByVal ConnectMode As
ext_ConnectMode, _
ByVal AddInInst As Object, _
Implements
IDTExtensibility2.OnConnection
MsgBox("Connecting to Mailcheker addin")
Private Sub IDTExtensibility2_OnDisconnection(ByVal RemoveMode As
ext_DisconnectMode, _
ByRef custom As
System.Array) Implements IDTExtensibility2.OnDisconnection
Private Sub IDTExtensibility2_OnStartupComplete(ByRef custom As
System.Array) _
Implements
IDTExtensibility2.OnStartupComplete
Msgbox("Mailchecker Startup complete")
End Class
It looks to me like your addin is a mixture of a shared addin and a VSTO
addin. A VSTO addin provides the Startup() and Shutdown() events, or at
least it does if the new disconnection registry setting is turned on. A
shared addin uses extensibility. You need to make up your mind as to which
you are trying to create, you can't mix and match.
You also need to post all the relevant information, such as if you are
running Outlook 2010 in 32-bit or 64-bit mode, which will make a huge
difference.
"CyberEeyor" <CyberEeyor> wrote in message
news:3D358956-52D9-46D6-B80E-881178E00CF8@microsoft.com...
> as
> this
> question.
> get
> at
> IDTExtensibility2
> addin.
> Thanks
> CyberEeyor
> Me.Startup
> End Sub
> Me.Shutdown
> End Sub
> System.Array) _
> Implements
> End Sub
> System.Array) _
> Implements
> End Sub
> _
> ext_ConnectMode, _
> ByRef custom As
> System.Array) _
> Implements
> End Sub
> ByRef custom As
> End Sub
> System.Array) _
> Implements
> End Sub
> End Class
B Outlook 2010 Outlook not connecting to servers at Comcast. Using Outlook 3
D Connecting to Exchange changes calendar functionality Exchange Server Administration 1
C connecting to recent outlook file on new hard drive Using Outlook 2
K BCM - Connecting to Shared Database BCM (Business Contact Manager) 0
I iPad not connecting correctly to Outlook.com account Using Outlook.com accounts in Outlook 7
N Outlooking not connecting. Connection present Using Outlook 1
S Connecting to OMA from Outlook ? Using Outlook 1
B Initial "Connecting" to public folders on startup Using Outlook 8
D Issues connecting to echange Using Outlook 7
S Outllook 2007 stops connecting with Exchange after latest MS Updates Using Outlook 2
D Connecting BCM 2007 to a shared BCM 2003 Database BCM (Business Contact Manager) 3
V Connecting BCM 2007 to SQL Server 2007 BCM (Business Contact Manager) 1
B connecting to shared database BCM (Business Contact Manager) 1
E Connecting to database failed BCM (Business Contact Manager) 3
B Problem connecting to local BCM database BCM (Business Contact Manager) 1
S Outlook 2016 and Acrobat PDFMaker Office COM Addin Using Outlook 0
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
Diane Poremsky Always Load an Outlook Addin Using Outlook 1
D Constant Dropbox Outlook Addin Authentication Prompts Using Outlook 5
T client addin deletes all business contacts BCM (Business Contact Manager) 1
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
M Icloud Addin in Outlook 2013 Exchange Server Administration 9
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
P Addin / macro / rule to highlight email addresses outside company in To: field Using Outlook 3
H Outlook 2010 Antispam Addin Not Available Using Outlook 1
S COM Addin Failed to load in Outlook 2003 Outlook VBA and Custom Forms 1
G Addin to define message format on a per-contact basis? Outlook VBA and Custom Forms 1
V how to collect details from user, during installation of office addin? Outlook VBA and Custom Forms 1
A how to enable macro for addin Outlook VBA and Custom Forms 3
T Regarding Outlook addin Outlook VBA and Custom Forms 1
N Drag and drop attachment in outlook addin Outlook VBA and Custom Forms 4
S Outlook addin formregion as a drop down Outlook VBA and Custom Forms 6
K Attach addin to outlook 2007 editor Outlook VBA and Custom Forms 3
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
N Support for outlook 2003 addin in xp home sp2 Outlook VBA and Custom Forms 3
J Addin to trap email item open Outlook VBA and Custom Forms 2
