Outlooking not connecting. Connection present
nickill2
I'm having issues with a computer at work. The user is trying to setup outlook, but everytime they start up outlook it shuts down, saying it can't connect to the exchange server. There is a network connection present. He has been using outlook threw OWA.
I've tried everything i can to get it to work. I've made a PST file, and that seemed to kinda help. It at least allowed me to get INTO outlook. Before it would just give the error and exit.
I've tried triple checking the exchange server, and it is correct. It will reach it when you setup a email account. but if you try to start up outlook, it just errors right on out.
OUTLOOK version 2007
Exchange version 2007 I think. (Dont honestly know)
Network connection IS PRESENT.
Does it start up if you use safe mode? To open Outlook in Safe mode: Close Outlook then hold Ctrl as you click on the Outlook icon. You'll get a message asking if you want to start in Safe mode. Click Ok.
Check the event viewer - are there any events for outlook?
Did you set up the account or did you use Outlook's auto account setup to create it?
B Outlook 2010 Outlook not connecting to servers at Comcast. Using Outlook 3
D Connecting to Exchange changes calendar functionality Exchange Server Administration 1
C connecting to recent outlook file on new hard drive Using Outlook 2
K BCM - Connecting to Shared Database BCM (Business Contact Manager) 0
I iPad not connecting correctly to Outlook.com account Using Outlook.com accounts in Outlook 7
S Connecting to OMA from Outlook ? Using Outlook 1
B Initial "Connecting" to public folders on startup Using Outlook 8
D Issues connecting to echange Using Outlook 7
S Outllook 2007 stops connecting with Exchange after latest MS Updates Using Outlook 2
D Connecting BCM 2007 to a shared BCM 2003 Database BCM (Business Contact Manager) 3
C Connecting to an addin in Outlook 2010 (or not) Outlook VBA and Custom Forms 1
V Connecting BCM 2007 to SQL Server 2007 BCM (Business Contact Manager) 1
B connecting to shared database BCM (Business Contact Manager) 1
E Connecting to database failed BCM (Business Contact Manager) 3
B Problem connecting to local BCM database BCM (Business Contact Manager) 1
e_a_g_l_e_p_i All of a sudden I lost connection to Gmail servers Using Outlook 8
W Encrypted connection to server refused Using Outlook 0
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
M Outlook 2010 Error: Your IMAP server closed the connection Using Outlook.com accounts in Outlook 1
M Outlook Email Connection Error Using Outlook 3
C Last Connection Using Outlook.com accounts in Outlook 1
K Work Email - Calander Connection to Outlook.com Using Outlook 2
R The action cannot be completed. The connection to Microsoft Exchange is unavailable. outlook must be Using Outlook 1
E IMAP server closed the connection Using Outlook 2
P Outlook Connection Issues Using Outlook 3
Z connection to Lotus Notes Using Outlook 4
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
K Intermittent ability to send to single domain. "Connection refused" Exchange Server Administration 1
N Connection Error Using Outlook 2
E intermittent "Your imap server closed the connection" messages Using Outlook 6
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
S Outlook connector, numerous versions, connection issues Using Outlook.com accounts in Outlook 1
S Remote connection to bcm BCM (Business Contact Manager) 1
D Event on connection mode change? Outlook VBA and Custom Forms 2
P Database connection problems BCM (Business Contact Manager) 1
J BCM connection problem BCM (Business Contact Manager) 3
