Remote connection to bcm
shs
I have sharing rights to the database but cannot connect. When I select the
database and put in the remote computer name it tells me it cannot be
located. Not sure what to do.
L
Leonid S. Knyshov // SBS Expert
Which BCM? Which Outlook? Are both of them the same version? Are both
computers on the same physical or wireless network? Can you ping the
other computer? Is the firewall disabled or configured for BCM ports on
the host computer?
Leonid S. Knyshov
Try Exchange Online http://bit.ly/free-exchange-trial
M trouble connection to remote database BCM (Business Contact Manager) 1
D Microsoft Exchange account - Remote management Using Outlook.com accounts in Outlook 1
M McAllister Outlook stops Sending/Receiving/Synching after disconnecting remote desktop session Using Outlook 2
R BCM 2010 Problem with remote office (VPN) users cannot connect BCM (Business Contact Manager) 12
K Aol and remote devices Using Outlook 1
T Shared BCM database on remote server BCM (Business Contact Manager) 1
S Cannot Find Shared Database on Remote Computer BCM (Business Contact Manager) 13
J BCM 2010 - New user cannot connect to remote DB BCM (Business Contact Manager) 5
H Mailing List account needed with remote smtp auth facility Exchange Server Administration 3
M BCM 2010 Cannot Connect to Remote Database BCM (Business Contact Manager) 1
A BCM 2010 & remote database BCM (Business Contact Manager) 3
D BCM and remote synchronization BCM (Business Contact Manager) 1
S will SQL 2003 work for remote server BCM (Business Contact Manager) 1
C Installing BCM 2007 on Remote Server with MS Server 2003 BCM (Business Contact Manager) 1
D Install SQL on a remote server for 2003? BCM (Business Contact Manager) 1
e_a_g_l_e_p_i All of a sudden I lost connection to Gmail servers Using Outlook 8
W Encrypted connection to server refused Using Outlook 0
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
M Outlook 2010 Error: Your IMAP server closed the connection Using Outlook.com accounts in Outlook 1
M Outlook Email Connection Error Using Outlook 3
C Last Connection Using Outlook.com accounts in Outlook 1
K Work Email - Calander Connection to Outlook.com Using Outlook 2
R The action cannot be completed. The connection to Microsoft Exchange is unavailable. outlook must be Using Outlook 1
E IMAP server closed the connection Using Outlook 2
P Outlook Connection Issues Using Outlook 3
Z connection to Lotus Notes Using Outlook 4
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
K Intermittent ability to send to single domain. "Connection refused" Exchange Server Administration 1
N Connection Error Using Outlook 2
E intermittent "Your imap server closed the connection" messages Using Outlook 6
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
N Outlooking not connecting. Connection present Using Outlook 1
S Outlook connector, numerous versions, connection issues Using Outlook.com accounts in Outlook 1
D Event on connection mode change? Outlook VBA and Custom Forms 2
P Database connection problems BCM (Business Contact Manager) 1
J BCM connection problem BCM (Business Contact Manager) 3
M Outlook 2007 "Connection Status..." shows 3 "Disconnected" entries of type "Directory" Using Outlook 18
T How to establish Soap Connection Outlook VBA and Custom Forms 5
M MSO OL sp2 for BCM broke SQL Database connection BCM (Business Contact Manager) 2
