How to establish Soap Connection
  • Thread starter Thread starter Thomas Weiler
Thomas Weiler
Iam trying to connect to a ASP.NET Webservice on another Server via
Outlook 2003 VBA. I´ve linked the "Microsoft Soap Type Library".
When I now go through the following code via debugger, it goes without
any error message. But on the Webserver nothing happens (Ived activate
the debugger on the ASP.NET Application and nothing happens).
What do I make wrong or what is missing in the code to establish a
correct connection?
-------------------------- snip --Dim msxml As New MSXML2.XMLHTTP
strEnvelope = _
"<soap:envelope
xmlns:soap=""urn:schemas-xmlsoap-org:soap.v1"">" & _
"<soap:header></soap:header>" & _
"<soap:body>" & _
"<myFunction xmlns='http://tempuri.org/'>" & _
"<var1>TextTextText</var1>" & _
"<var2>string</var2>" & _
"</myFunction>" & _
"</soap:body>" & _
"</soap:envelope>"
strServ = "http://myserver/myservice.asmx"
msxml.Open "post", strServ, False
msxml.setRequestHeader "Content-Type", "text/xml"
msxml.Send strEnvelope
-------------------------- snap --Thanks for all answers.
If your code gets executed at all, Outlook's part is done. For asp.net your
might need to answer in an appropriate newsgroup.
Best regards
Michael Bauer
Am Thu, 16 Jul 2009 15:05:24 +0200 schrieb Thomas Weiler:
> Hello,
> correct connection?
> -------------------------- snip --> Dim msxml As New MSXML2.XMLHTTP
> strEnvelope = _
> "<soap:envelope
> "<soap:body>" & _
> "</myFunction>" & _
> "</soap:body>" & _
> "</soap:envelope>"
> -------------------------- snap --> Thanks for all answers.
Thats the problem. The Webserver with the asp.net Webservice don`t get
any data (there is no entry in the web server log too). It seems that
the vba code goes through without doing anything.
Have you tried to set a breakpoint (f9) at the line:
and seen whether or not the line is called?
Best regards
Michael Bauer
Am Mon, 20 Jul 2009 07:54:56 +0200 schrieb Thomas Weiler:
your
Yes it is called and goes through but I get no action on the webservice.
Ok, that's what I thought. You need someone who can help with either the xml
library or asp/your webserver. In an appropriate newsgroup the chance for a
helpful answer should be better.
Best regards
Michael Bauer
Am Tue, 21 Jul 2009 15:22:26 +0200 schrieb Thomas Weiler:
e_a_g_l_e_p_i All of a sudden I lost connection to Gmail servers Using Outlook 8
W Encrypted connection to server refused Using Outlook 0
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
M Outlook 2010 Error: Your IMAP server closed the connection Using Outlook.com accounts in Outlook 1
M Outlook Email Connection Error Using Outlook 3
C Last Connection Using Outlook.com accounts in Outlook 1
K Work Email - Calander Connection to Outlook.com Using Outlook 2
R The action cannot be completed. The connection to Microsoft Exchange is unavailable. outlook must be Using Outlook 1
E IMAP server closed the connection Using Outlook 2
P Outlook Connection Issues Using Outlook 3
Z connection to Lotus Notes Using Outlook 4
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
K Intermittent ability to send to single domain. "Connection refused" Exchange Server Administration 1
N Connection Error Using Outlook 2
E intermittent "Your imap server closed the connection" messages Using Outlook 6
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
N Outlooking not connecting. Connection present Using Outlook 1
S Outlook connector, numerous versions, connection issues Using Outlook.com accounts in Outlook 1
S Remote connection to bcm BCM (Business Contact Manager) 1
D Event on connection mode change? Outlook VBA and Custom Forms 2
P Database connection problems BCM (Business Contact Manager) 1
J BCM connection problem BCM (Business Contact Manager) 3
M Outlook 2007 "Connection Status..." shows 3 "Disconnected" entries of type "Directory" Using Outlook 18
M trouble connection to remote database BCM (Business Contact Manager) 1
M MSO OL sp2 for BCM broke SQL Database connection BCM (Business Contact Manager) 2
