MSO OL sp2 for BCM broke SQL Database connection
MaitreMind
Two days ago an MS update for MSO OL sp2 for BCM wanted to be installed so I
left it get installed. After the installation I noticed that my data
connection to the BCM database was broken.
I am using MSSQLSERVER instance name for SQL Server Developer Edition
instead of MSSQL instance name which is for SQLEXPRESS. I have been usine SQL
Server Developer edition with BCM for quite awhile without any problem but
now after sp2 was installed I cannot connect to the database as it cannot
find it.
I ran the database Admin tool to share it and everything ran successfully
with a pretty instruction page that opened in IE to walk one through
connecting to the database in OL. The initial connection failed when I
selected the connect to an existing databse as it wanted to connect to the
default SQLEXPRESS instance, then I typed in the computer name
localhost\MSSQLSERVER,1433 and it cannot find the database to connect.
Has anyone else had this ridiculous issue and how can I solve it?
MaitreMind
L
Luther Blissett
On May 17, 10:58 pm, MaitreMind <MaitreM...
> instead of MSSQL instance name which is for SQLEXPRESS. I have been usineSQL
> find it.
> > Thanks,
> MaitreMind
By default, BCM creates and uses a sql instance named MSSMLBIZ, and
not the default instances. If Sql is installed by BCM Setup, it
doesn't even create the default instances.
Raul Thomas
Also the port number has to be 5356
Regards
Rahul Thomas [MSFT]
The posting is provided "AS IS" with no warranties and confers no rights.
https://blogs.msdn.com/rathomas
"Luther Blissett" <enowning@gmail.com> wrote in message
news:8b76678d-07df-4a7d-90ec-302034f49ca5@y33g2000prg.googlegroups.com...
> > so I
> > SQL
> > but
> > find it.
> > the
>> > > Thanks,
>> MaitreMind
D Max. length of MSO MailItem.EntryID Outlook VBA and Custom Forms 6
P BCM 2013, Microsoft SQL Server 2008 R2 (SP2), attachment issue n database size BCM (Business Contact Manager) 2
B Promoting and demoting dns w/ exchange 2007 sp2 environment Exchange Server Administration 1
J [outlook-users] outlook 2007 Sp2: Error message to quit outlook Using Outlook 9
R Clean out the "Other Calendars" form Outlook 2007 sp2 Using Outlook 1
Z Outlctl disabled (Outlook2007 SP2) Outlook VBA and Custom Forms 2
N Support for outlook 2003 addin in xp home sp2 Outlook VBA and Custom Forms 3
S Re: Cannot attach a file to an Outlook 2007 template after installingOffice 2007 SP2 Outlook VBA and Custom Forms 3
J Outlook 2007 with BCM - Out of Memory after MSO12 SP2 installation BCM (Business Contact Manager) 4
D Outlook 2007 + BCM & SP2 - windows7 ? BCM (Business Contact Manager) 6
Y Outlook 2007 SP2 issues Outlook VBA and Custom Forms 7
R Office 2007 SP2 Install: BCM Update Failure BCM (Business Contact Manager) 25
T Appoinments Not Updating after Outlook 2007 SP2 Outlook VBA and Custom Forms 1
A After update to SP2 (office 2007) Launching a campaign fails BCM (Business Contact Manager) 3
C After Office 2007 SP2 install - Outlook 2007 macro no longer worki Outlook VBA and Custom Forms 11
J BCM no longer loads sqlserver after SP2 upgrade BCM (Business Contact Manager) 2
