connection to Lotus Notes
zetag
Outlook 2013 64 bit
Good morning,
My problem on Outlook 2013 is that I'm connected with Notes server by SMTP (no exange server). I can see properly received mail but I can not see sended mail (I see only only "local mail" mail sended by outlook). I don't find solution in Italian forum, could you help me? My English is not very good, please use "basic English" for answer. Thanks a log
Is the Sent folder displayed in the folder list? If not, you need to subscribe to it - right click on a folder in your imap account and choose IMAP folders. Then click query. The sent folder should have a yellow folder beside it . if not, select the folder and click Subscribe.
Is the folder name in Italian? Outlook normally gets the Sent folder name from the server, but Notes may not send it.
Thank you very much Diane. I can not subscribe Send folder because query don't find it.
Idon't think that notes use folder name in Italian (but I'm not sure). On my framework I read "Inviati"
bye
e_a_g_l_e_p_i All of a sudden I lost connection to Gmail servers Using Outlook 8
W Encrypted connection to server refused Using Outlook 0
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
M Outlook 2010 Error: Your IMAP server closed the connection Using Outlook.com accounts in Outlook 1
M Outlook Email Connection Error Using Outlook 3
C Last Connection Using Outlook.com accounts in Outlook 1
K Work Email - Calander Connection to Outlook.com Using Outlook 2
R The action cannot be completed. The connection to Microsoft Exchange is unavailable. outlook must be Using Outlook 1
E IMAP server closed the connection Using Outlook 2
P Outlook Connection Issues Using Outlook 3
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
K Intermittent ability to send to single domain. "Connection refused" Exchange Server Administration 1
N Connection Error Using Outlook 2
E intermittent "Your imap server closed the connection" messages Using Outlook 6
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
N Outlooking not connecting. Connection present Using Outlook 1
S Outlook connector, numerous versions, connection issues Using Outlook.com accounts in Outlook 1
S Remote connection to bcm BCM (Business Contact Manager) 1
D Event on connection mode change? Outlook VBA and Custom Forms 2
P Database connection problems BCM (Business Contact Manager) 1
J BCM connection problem BCM (Business Contact Manager) 3
M Outlook 2007 "Connection Status..." shows 3 "Disconnected" entries of type "Directory" Using Outlook 18
T How to establish Soap Connection Outlook VBA and Custom Forms 5
M trouble connection to remote database BCM (Business Contact Manager) 1
M MSO OL sp2 for BCM broke SQL Database connection BCM (Business Contact Manager) 2
F This is currently a Lotus Notes app. Can Outlook / Exchange do this ? Using Outlook 3
C Outlook 2007 meeting invitations and Lotus Notes Using Outlook 0
D Error "not supported calendar message.ics" on Lotus Notes Exchange Server Administration 3
B Outlook or iPhone turning tabs into spaces in Outlook Notes Using Outlook 1
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
P Task display now leaves little room for notes Using Outlook 10
