Database connection problems
P
pwbre
By database connection drops out intermittenly while all others on the
network remain connected, is there a solution to this?
Raul Thomas
Try creating an offline database and see if it does the trick for you
Regards
Rahul Thomas [MSFT]
The posting is provided "AS IS" with no warranties and confers no rights.
https://blogs.msdn.com/rathomas
"pwbre" <pwbre> wrote in message
news:51E7FDA8-DA7B-47DD-8435-01FAE68FE9A4@microsoft.com...
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
M trouble connection to remote database BCM (Business Contact Manager) 1
M MSO OL sp2 for BCM broke SQL Database connection BCM (Business Contact Manager) 2
A Moving Public Folders to New Database Exchange Server Administration 3
wallisellener "The database name cannot exceed 50 characters" BCM (Business Contact Manager) 2
S Encrypting Exchange Database Exchange Server Administration 0
R Outlook Database to a non-Outlook PC Using Outlook 10
A use database in other office BCM (Business Contact Manager) 1
K Recover/preserve space in database BCM (Business Contact Manager) 0
P Restoring old sbb database in existing one BCM (Business Contact Manager) 4
J Install BCM Client without an local SQl Database BCM (Business Contact Manager) 6
M Sharing of BCM database across the internet BCM (Business Contact Manager) 2
Chris Grew Sharing BCM Database BCM (Business Contact Manager) 6
S Updating the database based on received task Outlook VBA and Custom Forms 3
J What exactly does the BCM Database tool actually do? BCM (Business Contact Manager) 3
J How do I get the database tool to recognize my data file? BCM (Business Contact Manager) 2
C Moving BCM Database to Server Share BCM (Business Contact Manager) 1
D Open attached CSV, copy newdata and paste it to database CSV Outlook VBA and Custom Forms 2
K BCM - Connecting to Shared Database BCM (Business Contact Manager) 0
B Can't see database in multiuser BCM (Business Contact Manager) 1
S Passive Mailbox database Resynchronization issue Exchange Server Administration 1
J Can the BCM Database tool be used over VPN? BCM (Business Contact Manager) 6
D can you share a bcm database with 2 different versions of windows? BCM (Business Contact Manager) 0
T BCM database scheme BCM (Business Contact Manager) 5
E BCM Database Tool Using Outlook 2
G "database is not compatible with BCM for Outlook 2013" & more BCM (Business Contact Manager) 0
L BCM database not listed BCM (Business Contact Manager) 0
wallisellener database creation failed BCM (Business Contact Manager) 0
J No errors from BCM 2007 but can't see database BCM (Business Contact Manager) 0
P BCM 2013, Microsoft SQL Server 2008 R2 (SP2), attachment issue n database size BCM (Business Contact Manager) 2
T BCM Cannot See Existing Database BCM (Business Contact Manager) 2
R catalog Content Index failed-Unable to mount database.(hr=0x80004005,ec=-501) Exchange Server Administration 0
T Shared BCM database on remote server BCM (Business Contact Manager) 1
C My BCM Database is no longer available to be shared with the Database Tool BCM (Business Contact Manager) 3
wallisellener Server configuration for BCM 2013 shared database BCM (Business Contact Manager) 15
S Cannot Find Shared Database on Remote Computer BCM (Business Contact Manager) 13
M BCM in Outlook reports maximum database size to 4GB despite SQL Server 2008 R2 BCM (Business Contact Manager) 1
A delete database --> record remnants ?? BCM (Business Contact Manager) 3
D BCM Database Protection BCM (Business Contact Manager) 3
U Exchange 2010 & mailbox database Quotas Exchange Server Administration 1
M BCM 2010 Cannot Connect to Remote Database BCM (Business Contact Manager) 1
