All of a sudden I lost connection to Gmail servers
e_a_g_l_e_p_i
I have been getting all my Gmail on Outlook 2010 since a week ago when my issue was resolved.
Today I ran a security check on Google to make my Gmail as secure as possible. It found that I had a third party accessing my Gmail, it showed that it was ThunderBird which is what I used to get my Gmail before setting it up on Outlook 2010. Since I wasn't going to use ThunderBird to access Gmail any longer I removed access to the third party access ( ThunderBird ) as soon as I did that I could no longer get my Gmail in Outlook 2010. It has to be related to me removing third party access to ThunderBird.
I removed Gmail from Outlook and re-added it and it still doesn't work, I kept getting the popup box that shows my login info, no matter what I do it keeps popping up and Gmail doesn't connect to servers.
I Googled how to give third party access and everything I read says that under security settings in Gmail there is a third party section where I can manage access. I don't have that under my security settings. So now I removed Gmail form Outlook 2010 otherwise that popup login box keeps popping up and I can do a thing.
I would appreciate any and all help
Ron
Ron
***UPDATE***
There is no "manage third party access " in Google security settings. The fix is to enable "Allow less secure apps to access Gmail"
By default Google turns it off to make Gmail more secure, Google tells you it is not recommended to turn it on so I didn't, even though I wanted to try it.
I posted here and Google help community and the reply I got from the Google help community was to turn on "Allow less secure apps to access Gmail"
I should get brownie points for posting a question and then finding my own answer..........LMAO
Oh, and if outlook errors trying to check gmail, check that setting first - google like to turn it off. It should stay on if you only access from a desktop, but if you use a laptop and change ip's, it will cut you off. BTDT, too many times before I gave up and turned on 2FA.
I only use my desktop, too old to trust my phone........lol I find it amazing how most younger and business people use their phones to live on. there is no way I would have my passwords ( I used RoboForm for all my logins ) if I lost my phone and wasn't logged out people could access my banking etc. so I am a desktop user and always will be :)
I felt the same way about my phone - when I had an iPhone 6. It was *slow*. I finally replaced it with an iPhone 12 and wow - I was shocked at much much easier it is to use when I don't need to hurry up and wait.
With me and keeping my life on my phone it wasn't the speed of the phone it was the risk of losing it and then if someone found it before I did, they would have access to all my info and accounts. I decided years ago there is nothing that I can't wait until I get home to check my desktop.......lol
Does 2FA make you confirm it's you in Outlook? or just when you login from the web? I do change my ip using a VPN so if that will affect Outlook 2FA might be a good idea as long as I don't have to worry about it asking me to verify every time outlook checks for mail.
I Outlook 2024 Windows 11 Gmail - sudden log in problems Using Outlook 14
M Sudden change in From field - now very short Using Outlook 4
Maybear Sudden change in Outlook, no image display, email no longer offers suggestions for address Using Outlook 8
A OL 2007 problem - sudden large increase in message size Using Outlook 12
S Email was migrated from GoDaddy to Microsoft exchange. We lost IMAP ability Exchange Server Administration 1
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
L Format Lost between Tasks and To Do Using Outlook 0
Horsepower Lost emails Using Outlook 4
Abraham Outlook 2013 Lost my folders when moving from PST to IMAP Using Outlook 11
Witzker Customized Ribbon lost every now and then Using Outlook 3
M Transfer To New Computer - Lost Some Outlook Functionality Using Outlook 0
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
K Lost Rules. Assistant accesses my mailbox. Disappeared Using Outlook 0
E 365 Outlook changed from POP3 to IMAP,all contacts lost Using Outlook 3
DAVID A moved the Outlook CST file - All subfolders lost Using Outlook 2
J Contacts 2016 Web page address content lost after updates Using Outlook 2
R Lost PST files after format Using Outlook 6
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
fitzgerald Lost PST files after format - how to recover deleted files? Using Outlook 3
L Recurring Tasks lost Using Outlook 3
R Lost Outlook 2013 Contacts for Gmail Account (OST files) Using Outlook 1
Nick Truscott Lost custom forms after moving mailbox Outlook VBA and Custom Forms 3
H Lost Custom Forms when we replaced Exchange Server Outlook VBA and Custom Forms 3
O Lost Emails after I connected my outlook.com to Office Outlook Using Outlook.com accounts in Outlook 1
J Lost email categories when migrating from Office 2010 to Office 2013 Using Outlook 3
M Lost calendar entries Using Outlook 11
K Lost Contacts Using Outlook 3
G Content Lost From Draft, Returns Upon Refocus? Using Outlook 0
J Lost contacts.pst afer sync with iCloud: where has contact.pst disapperaed to? Using Outlook 3
E lost contacts on emptying outbox? Using Outlook 5
C Newb Q: Outlook 2013 Lost Contacts (this computer only) Using Outlook 4
V Lost calendar view, items still in list view Using Outlook 2
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
C Lost calendar and contacts to icloud: Help! Using Outlook 1
L Excel table format lost in Outlook Using Outlook 6
B Lost entire Contact Folder in Outlook 2013 - Cloud-based. Using Outlook 1
F lost 95% of contacts Using Outlook 2
N Lost archived emails Using Outlook 3
R Lost Outlook 2007 message found in OWA Using Outlook 4
A Lost OE data when upgrading to Windows 8 Using Outlook 1
D Lost Inbox messages Using Outlook 2
N Changed the "sender" account and lost all my text Using Outlook 2
J Outlook replacement options - contact journal activities lost Using Outlook 23
I I've lost my Notes upgrading to Windows 7 Exchange Server Administration 3
G Manually created Sent Items folder is lost Using Outlook 4
D outlook 2010 table format lost on send Using Outlook 1
