Browse Dialog Box
  • Thread starter Thread starter Brad
Brad
Thanks for taking the time to ready my question.
I have a sub that helps me save an e-mail message to a folder on my
computer. What I have to do at the moment is type the full path into an
InputBox. What I'd like to do is have a dialog box pop up that has a browse
button on it. I can do this in MS Access, and copied my code over, but it
doesn't work in Outlook.
Does anyone know where I might find this type of code so I can use it in
Outlook?
Here is what I use in Access:
Option Compare Database
Option Explicit
'************** Code Start **************
'This code was originally written by Terry Kreft.
'It is not to be altered or distributed,
'except as part of an application.
'You are free to use it in any application,
'provided the copyright notice is left unchanged.
'Code courtesy of
'Terry Kreft
Private Type BROWSEINFO
hOwner As Long
pidlRoot As Long
pszDisplayName As String
lpszTitle As String
ulFlags As Long
lpfn As Long
lParam As Long
iImage As Long
End Type
Private Declare Function SHGetPathFromIDList Lib "shell32.dll" Alias _
"SHGetPathFromIDListA" (ByVal pidl As Long, _
ByVal pszPath As String) As Long
Private Declare Function SHBrowseForFolder Lib "shell32.dll" Alias _
"SHBrowseForFolderA" (lpBrowseInfo As BROWSEINFO) _
As Long
Private Const BIF_RETURNONLYFSDIRS = &H1
Public Function BrowseFolder(szDialogTitle As String) As String
Dim x As Long, bi As BROWSEINFO, dwIList As Long
Dim szPath As String, wPos As Integer
With bi
> hOwner = hWndAccessApp
> lpszTitle = szDialogTitle
> ulFlags = BIF_RETURNONLYFSDIRS
dwIList = SHBrowseForFolder(bi)
szPath = Space$(512)
x = SHGetPathFromIDList(ByVal dwIList, ByVal szPath)
If x Then
wPos = InStr(szPath, Chr(0))
BrowseFolder = Left$(szPath, wPos - 1)
BrowseFolder = vbNullString
End Function
'*********** Code End *****************
Other than the Option Compare Database that should work as well in Outlook
VBA as it does in Access VBA. What problems are you having with it?
"Brad" <Brad> wrote in message
news:7B3998A8-4A5C-4505-B896-A4966C490B29@microsoft.com...
> browse
> Outlook?
> Option Explicit
> 'Code courtesy of
> 'Terry Kreft
> hOwner As Long
> pidlRoot As Long
> lpszTitle As String
> ulFlags As Long
> lpfn As Long
> lParam As Long
> iImage As Long
> End Type
> As Long
> With bi
> .hOwner = hWndAccessApp
> .lpszTitle = szDialogTitle
> .ulFlags = BIF_RETURNONLYFSDIRS
> End With
> If x Then
> Else
> End If
> End Function
T Unable to 'Upload a file' using popup 'Browse' button Using Outlook 0
J Save Dialog Outlook VBA and Custom Forms 2
J Hide/Disable the X button on BrowseForFolder Dialog Using Outlook 4
U Disable "Always ask before opening" Dialog Using Outlook 3
D.Moore PickFolder dialog "extension" Outlook VBA and Custom Forms 0
S Reminder Dialog Open Button Using Outlook 2
Laurent Duchastel New email setup dialog doesn't allow alias Using Outlook 2
M Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
Diane Poremsky Enter Network Password Dialog Keeps Popping Up Using Outlook 0
Diane Poremsky Rules & Alerts Dialog Won't Open Using Outlook 1
N Outlook dialog about retention policy Using Outlook 3
P VBA for Dialog Box when sending Email Using Outlook 8
R how do I eliminate allow access dialog box using VBAproject in Out Outlook VBA and Custom Forms 1
J Select Names Dialog Box Outlook VBA and Custom Forms 16
P Open Advanced Search Dialog Outlook VBA and Custom Forms 1
A outlook AdvanceFind dialog Outlook VBA and Custom Forms 5
S how to add my custom items to "Change E-mail Account" dialog Outlook VBA and Custom Forms 1
J Save As dialog box on screen Outlook VBA and Custom Forms 1
H How turn off outlook security warning dialog box from outlook Outlook VBA and Custom Forms 1
R (Outlook2003)Monitor change for "to" "cc" "bcc" on message compose dialog? Outlook VBA and Custom Forms 6
P How to Open File Selector dialog in VBA Outlook VBA and Custom Forms 4
J common dialog Outlook VBA and Custom Forms 1
B how/what dialog boxes can I display from VBA code Outlook VBA and Custom Forms 1
A Search People>press enter box disappears. Using Outlook 3
S Default Selection For Multi-Select List Box Outlook VBA and Custom Forms 1
A GetSelectNamesDialog Pre-fill search box Outlook VBA and Custom Forms 12
P Custom Outlook form_Validations in combo box Outlook VBA and Custom Forms 0
