Outlook 2021 Using vba code to delete all my spamfolders not only the default one.
Djutoch
Outlook 2021 32 bit
I have this code to clear spamfolder in the default account but I would like to adapt the code so it works for multiple accounts, not only the default one.
Thanks in advance.
Sub del()
   Dim objJunkFolder As Outlook.Folder
    Dim i As Long
    Dim objDeletedFolder As Outlook.Folder
    Dim objItem As Object
    Dim objProperty As Outlook.UserProperty
    Set objJunkFolder = Outlook.Application.Session.GetDefaultFolder(olFolderJunk)
    For i = objJunkFolder.Items.Count To 1 Step -1
        If objJunkFolder.Items(i).Class = olMail Then
           Set objMail = objJunkFolder.Items(i)
           'Add the specific property to each junk email
           objMail.UserProperties.Add "Delete", olText
           objMail.Save
           'Delete them
           objMail.Delete
    Set objDeletedFolder = Application.Session.GetDefaultFolder(olFolderDeletedItems)
    For Each objItem In objDeletedFolder.Items
        'Find out the junk emails in the "Deleted Items" folder
        Set objProperty = objItem.UserProperties.Find("Delete")
        If TypeName(objProperty) <> "Nothing" Then
           'Permanently delete them
           objItem.Delete
    'Prompt You
    MsgBox Chr(34) & "Ongewenste mail" & Chr(34) & " Folder geledigd !", vbExclamation + vbOKOnly
A Accessing .pst folder in outlook using VBA Code Outlook VBA and Custom Forms 4
Geldner Problem submitting SPAM using Outlook VBA Form Outlook VBA and Custom Forms 2
U Using VBA to creat hyperlinks in an email Outlook VBA and Custom Forms 3
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
Diane Poremsky Create a Series of Tasks using VBA Using Outlook 0
Diane Poremsky Paste clipboard contents using VBA Using Outlook 0
L Clear Offline (Task) Items using VBA Outlook VBA and Custom Forms 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
J Using VBA to disable alerts / warnings Using Outlook 2
P Saving All Messages to the Hard Drive Using VBA Outlook VBA and Custom Forms 5
M using Folders.Count in Excel Vba Outlook VBA and Custom Forms 8
M VBA Send Sales reports using .oft files, originate in Outlook or Excel? Using Outlook 5
A Outlook VBA - moving mail item to public folder using variable within path Using Outlook 6
P Automatic reply on incoming messages in outlook using VBA(only Specifi person) Using Outlook 14
D Update existing rule using VBA Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
J Add categories to Shared Mailbox using VBA Using Outlook 2
R Limiting meeting attendees using VBA or an add-in Using Outlook 9
J Create new outlook task into task subfolder using vba Using Outlook 6
S Send All emails in Outbox and Quit using VBA Outlook VBA and Custom Forms 3
R Outlook and Access integration using VBA Outlook VBA and Custom Forms 1
