using Folders.Count in Excel Vba
Mark Scholes
Outlook 2013 32 bit
I am using outlook 2013 (32 bit) and I have this piece of code in my Excel spread sheet. It finds a e-mail in a folder opens it and extracts the spread sheet. The part of the code which finds the folder now doesn't work, it did work in outlook 2010 (32Bit)
Set mynamespace = Outlook.Application.GetNamespace("MAPI")
' Set the Source to the mail Inbox folder for AFMA Green data
' Set the Target to the mail sub folder for archiveing
Set SourceFolder = mynamespace.Folders("Risk Quantitative")
' Find the Inbox
iLoopcounter = 1
Do Until iLoopcounter > SourceFolder.Folders.Count
If SourceFolder.Folders(iLoopcounter) = "Inbox" Then
Set SourceFolder = SourceFolder.Folders(iLoopcounter)
Exit Do
iLoopcounter = iLoopcounter + 1
Loop
When you run ? SourceFolder.Folders.count you should get 13, I now only get 0 and so the next piece of code fails
' Find AFMA Green
iLoopcounter = 1
If SourceFolder.Folders(iLoopcounter) = "AFMA Green" Then
Exit Do
Loop
To add to the problem I have Four mailboxes
Any thought would be great
Mark Scholes
I added debug prints after the loop counter is set, and after each increment. I get:
1 Start
2 Inbox
14afma green
The only change I made was to change the mailbox name and the folder names to ones that exist here.
I have several e-mail accounts in the same profile. If I have only one email account in the profile it works fine.
You get a error 'Run-time error '440': Array index out of bounds.' which is reasonable as the line reads 'Set TargetFolder = SourceFolder.Folders(1)'
Silly thought, Where do I fine which version of outlook 2013 I have and what is the latest version. IT update out software and we don't use Microsoft update, and I don't know if it up to date.
Thanks for your reply
I'd don't think the version matters - the code should work in all versions but you can look in File, Office account.
The problem is that 'Set TargetFolder = SourceFolder.Folders(1)' is having problems finding the right folders, I'm sure its related to the # of mailboxes, although I have 3 + a bunch of shared mailboxes and it worked for me.
I have updated to the latest version and this problem has gone. I have no idea if it was the Office 2013 updates or the Windows 8.1 updates that they did at the same time
N Using Categories & Search Folders with multiple accounts Using Outlook 4
D folders are missing using imap outlook 2007 Using Outlook 1
P move folders in outlook using vba Outlook VBA and Custom Forms 1
